If your car is fitted with four Weber IDF carburetors, they will have to be individually adjusted for mixture and idle speed.This requires disconnecting them from the main throttle control linkage first. You must also have a Unisyn, or similar air flow measuring device to synchronize throttle plate openings at idle. It's a relative simple procedure, however not something a novice should attempt without the carb adjustment manual present. When finished with basic adjustments, the carbs must be reconnected to the main linkage where the central idle speed adjusting screw will be found. If your car is injected, idle speed should be automatically controlled by an electronic 'Idle Speed Stabilizer'. A photo of the motor, with air cleaner removed, will be helpful in determining what system you actually
have.
SOURCE: aston martin vantage problem
the battery is dead or battery switched off located at inside baggage right hand side.switch it on by pushing the button.
SOURCE: the a/c is not working !?? aston martin v8 vantage
how much water is in it.
is it all hooked up?
take it to the nearest cr dealers and ask if they can help you.i hope i helped.
SOURCE: my petrol cap is stuck on my aston martin vantage
Hi and welcome to FixYa!
As a first course of action I strongly suggest that you put pressure on the cap when turning counter clockwise. This can really happen for there's fuel pressure on the tank.
Hope this helps and thank you for using FixYa! Have a good one!
SOURCE: I have a brand new
" ALARM SYSTEM SERVICE REQUIRED
i think this the battery, ur car still new go to the local dealer.
