Not enough memory when played music
SOURCE: When i play radio or music player in my nokia
just remove the memory card and put it back again.
SOURCE: my 5220 music player dont work and calculator is gone
press *#7370#
to format ur phone... by providing nokia default security code: 12345 or
u can reinstall software via nokia software updater using internet,,,, hope ur problem will be gone,,,,
SOURCE: Not enough memory error when trying to play a
hi,
5220 is a baseband 5 unit of nokia ,an express music
phone...because of it many function like music player,video etc,its
software is very sensitive...that trouble cannot fix by any reset code
,formatting ,hard reset or factory setting...you need to go to a nokia
care center or expert mobile technician to reprogram your cellphone by
an appropriate software because that phone cannot be DOWNGRADED
to prevent more damage in your cellphone...thanks for trusting fixya ,i hope it will help you..
SOURCE: nokia 5220 xpress music... have
If it says not enough memory, you need to free up some space in your phone by deleting unnecessary files. Or you can add a memory card to your phone so you can add more songs. Hope this helps!
SOURCE: not enough memory display when
try first deleting or erasing some of your stored messages, example sent items or inbox old items.
you can also try erasing received file or moving them to the mmc location.
also you can restore the phone factory settings, by going to settings and select restore or reset factory setting, but before doing that, be sure to BACKUP all your needed data.
