Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
<!-- from fixya rte -->Reset tv sony kdl-37l4000 - Sony Bravia KDL-37M4000 37 in. LCD HDTV
    Top Expert:
  • Sony Master
  • 76,237 Answers
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Sep 07, 2014
2 Suggested Answers
Anonymous
SOURCE:
Steve Yocum
  • 668 Answers
SOURCE: can i change ntsc system to multi system on my
It is not designed to be changed over. Even if it was, it would probably cost more to do it than what it would be worth.
Posted on Jul 04, 2009
How can I reduce heat on sony lcd kdl-37l4000
By not using it so much. Televisions heat up if left on too long.
Aug 19, 2014 | Televison & Video
Sony bravia model kdl-37l4000 has sound but no picture
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 06, 2014 | Televison & Video
Gray bar on bottom of picture when playing dvd
If only when playing a dvd it is not likely to be a problem with the TV set--have you checked to see if issue when played at another set?
Nov 03, 2012 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
I have a Sony Bravia 32" LCD tv...my query is that if the tv will be suitable in 110voltage plug or we should change it to 220 volt?
try to check first the voltage requirements at the back of your tv it is printed there, but most of the tv models specially the lcd it is auto volts.
Jul 10, 2011 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
When you push the power button on the TV, the green power light will come on but the back light won't light up and the picture won't come up. I tried to contact Sony and all they could tell me was to take...
Yes it is best to bring it in the nearest service center. just to clear it for you, your TV has problem with the power inverter. If your TV stays On and you can hear the audio but your screen is dead set black.
If yes, your problem is with the ballast or inverter this gives the luminous light on the screen in each side for you to see the clarity of the picture. try to replace this defective inverter or have it repair. this is the same remedy the technician in the service center will do.
well hope this helps, please rate and vote.
Mar 20, 2011 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Backlight on no picture
Sony Bravias have bad power supplies. I would contact sony customer service
Feb 28, 2011 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
The av and hdmi loggo at top right hand corner
hit the display button on remote should turn it off
Feb 04, 2010 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Change voltage from 120v to 240v sony bravia 37L4000
I think that Sony Bravia are sold with dual voltage, 110V and 220V. All 220V devices work also on British 240V network.
If an electronic device is not compatible with the 240V/220V network, then the PSU must be replaced.
In your case the unit should be dual voltage, compatible with 220/240V networks. Just ensure checking the user manual, or the tag at the back of TV.
All you need in that case is an adapter that can be purchased at any local electrical shop (eg. Curry's if you are in UK).
Regards.
Jul 26, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Can i change ntsc system to multi system on my sony tv BRAVIA KDL-37L4000
Jul 04, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
