Fully charged, was working fine
Maybe it's not completely off. Hold down the power button for at least 20 seconds. The hit it again to turn it back on.
If it's not charged, after doing that, you'll need to plug it in for at least 15 minutes.
You may have to do a factory restart. Try the things on this list and if all else fails and you have to perform a factory restart, this will show you how.
http://www.lovemyfire.com/kindle-fire-reset.html
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: Kindle locked up and now can't get it to turn on.
I have the same problem. The screen saver is partially frozen on the screen on the upper right corner and then blank down the rest of the right side. The rest of the screen is readable and I'm able navigate (turn pages, select different books, etc).
Did you figure anything out? Help!
SOURCE: `kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
SOURCE: kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed
the battery life diminishing before it wouldn't charge this may
be the case. Here is a site that has replacement batteries for the
Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
