Our new ice maker filled with water to bottom of ice tray, turned on, makes slight noise then fill water light comes on & no compressor noise. Fill water light stays on.
SOURCE: Good Morning - I need to order a Ice Shovel Part
It's actually made by Magic Chef model MCIM30TS. Get parts directly from MagicChef www.mcappliance.com or www.repairclinic.com
SOURCE: I just received a Sunpentown
The outside male thread drain should have a cap to hold the water; this is the drain for draining the unit. Filling the unit is as you described, simply lift the lid and add water into the tub. It should not be leaking water from under the unit ... that could be a problem. Good luck!
