The Little Green Triangle (LGT) is an indicator to alert you to a potential error in your formula. The LGT doesn't stop you from entering a formula (with or without an error), it's just an alert to check that it's OK. If you're happy with the formula you've entered, then you can just ignore the LGT and carry on.
If it's bugging you, you can turn off background error checking.
Go Tools / Error Checking / Options / and uncheck "Enable background error checking". That will turn off the LGTs.
SOURCE: How do I say look at cell on left rather than the cell number
vlookup can only locate values within the lookup range and to the right of the lookup column. to address your concern, i'd advise you to create a dummy column within the lookup range (and hide it) and link it to the lookup column. this way, we won't need a (-) column index number.
SOURCE: When I enter a formula the cell displays the
You can change this under the Excel, options menu. Select the advanced option and uncheck the option to "Show Formulas in cells instead of their calculated value", or you can jjst press Ctrl + `
This will either turn on or off the show formula option.
SOURCE: Problem was found in Micorsoft
Once you have copy the cell from where the formula cam from, on the destination cell,
go to
1. Edit
2. Paste Special
3. Formula.
4. Press Enter
This should resolve your problem. Regards.
