When I turn the radios on the battery icon shows full. If I don't press the talk button I can hear others transmit if they're on the same channel. As soon as I press the talk button The radios' low battery icon appears and I can't transmit.
Are you SURE that your batteries are up to snuff? I.E. when they have a light current load on them they are ok but as soon as you try to increase that current load they die off quickly. With two-way radios, the actual current drain depends on whether you are transmitting or in standby (receive) mode. Transmitting requires significantly more current than standby mode. So, I would look at what kind of batteries you are using. If they are a good name brand alkaline, check to see if they measure close to 1.5 volts with a voltmeter or check them with a battery tester to ensure they are good. If they are ni-cad or ni-mh rechargeable batteries, make sure they are rated at least 1200 mah (milliamp hour). I use Sanyo eneloop rechargeable batteries. They last a long time for me. One other thing, make sure your battery compartment is clean and there is no corrosion on the contacts the batteries are placed into.
Hope this helps,
Jim
SOURCE: I BUY 2 WAY RADIOS MOTOROLA XU2100 OFTEN BUT
1) Clean all your battery contacts with a pencil eraser. This includes the contacts on the charger (if a drop-in style), battery and the radio.
2) Check your battery date code. It is a 4 digit number on the white portion of your battery. The first two numbers are the year, followed by the week of the year. (Example: 0946 would be 2009 the 46th week.) Your battery pack should be less than 2 years old to work correctly.
3) Check to see you are using the correct charger. The XTN style charger should have a white label on the cord indicating it is for the XTN radio.
You most likely have batteries which are failing or shorted out. It would be advisable to remove them from the radio and replace them with new batteries. Continued charging of shorted/bad batteries will damage your radio.
Best regards.
SOURCE: Motorla Xtn446 - Kenwood Protalk Dosent Transmit
One or both of your radios have PL ( aka private line, tone code, interference eliminators) activated. Here is a link to a link which contains the XTN446 manual(s). Click on the "support" tab to see the list: http://www.motorola.com/Business/XU-EN/Business+Product+and+Services/Unlicensed+Two+Way+Business+Radios/XTR446_XU-EN
First I would try setting the radio's CODE to off (usually zero) and see if that solves the problem. Otherwise, you'll either need to experiment, or find a user guide for the Kenwood. (You could try posting in the Kenwood forum.)
Best regards.
SOURCE: Icom IC-A6 Airband radio keeps going off when trying to transmit
This is likely the result of a high current draw, ie too high for the battery capacity, which could be simple partially discharged batteries. Have you tried transmitting on low power? Does that make a difference?
It would appear from the voltage that you are using rechargeable batteries such as NiMH which have a lower full charge voltage than alkaline cells. Though I have never used the A6, I do have several Icom handhelds, amateur and marine and they work fine using the NiMH cells, though it is possible that alkalines may help--it's worth a try.
If none of the above makes a difference it would appear that something in the transmitter circuits is drawing too much current. A likely suspect (unfortunately) is the power transistor. Ouch. Good luck. Let us know what you find.
