The screen is a pink color. How do I fix this
SOURCE: kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
SOURCE: Sony KDL-40S2010 40" LCD TV
not cheap at all, that's the prism off balance, most easy cases 200 to 400 to fix.
SOURCE: The color on my tv is mostly pink. Is this
Try a reset to factory defaults. Show some image with lots of white. If it is still pink, it could be the backlights starting to fail. Or a circuit board. To be sure, you would have to disconnect the LCD panel from the board and turn on the set so that you have a blank white screen....with no signal. A pink screen, backlights are bad.
