Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
