How to change a discharge hose
SOURCE: Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
SOURCE: it is a door switch for Kenmore 80 series top load
I'm not sure what your question is but following is the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.25842400
If you look in the top and cabinet section, you'll see a description of the Lid Switch.
If you need to replace it, you'll have to remove the cabinet first.
Following is a site with a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=534500897c8bf705d91c620362438f0e
SOURCE: Kenmore type 111, very weak spin
Clothes do not spin out good on NORMAL regular express, but do on casual.
SOURCE: my kenmore 90 series washer won't spin or
true. there is no belt on this model. most likely, the motor coupler has broken. very inexpensive part and fairly easy to replace if you have about an hour. the old part was all plastic and the new part has some reinforced metal in the center. these parts break easy, especially if the person washing lets the machine run off balance all the time.
SOURCE: Kenmore type 111 has standing water inside how do I get it out?
some water is left to keep the drum seal moist.
you should not be able to see the water.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
