I can not power up the machine the wall sockets work. Is there a way to reset the machine
SOURCE: How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
SOURCE: Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to
it broken), water pump open circuit (although that would stop the water
draining too) Pressure chamber blocked or pressure tubing pipe looped
below the pressure bottle, or a sticking eco ball in the sump hose
(sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
