You can write off bad clusters by performing a low level format, this will ERASE THE CONTENTS in the process so you will want to back up all files first. Seatools is a free utility capable of performing a low level format, be sure you format the correct drive. However if more bad clusters start reporting after the low level format I would recommend replacing the drive as a few are normal but more showing up soon after is generally a sign the drive is failing.
