SOURCE: Can't find the code to program RCA RTD207 dvd home theater system
try these codes:
here is another way to program the remote:
thanks
tom
SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
SOURCE: I have an RCA Home Theater System Model Number
Make sure that ALL ur cable r well conected! Sometimes just by moving cables it makes a difference.
SOURCE: RCA RTD315 Theater System The DVD Player recently
My identical system has exactly the same problem as the one described by dipaola, above. When I insert a DVD, the DVD carriage pops back open after a few seconds. In fact, mine won't stay closed even without a DVD in it, as long as the system is set to play a DVD. I'd like an answer to the big Q - Is there anything I can do about this, or should I just find another DVD player to hook into the system?
