Need service manual or instructions on replacing the needle/clamp bar. Shop said it is the only way to treat the recurring problem. I am handy and would love to keep from putting so many $$ in repair of an older machine. Thanks!!
SOURCE: I have a Brother KH970 Knitting machine from a
I have a parts manual & a service manual saved on my pc for the 970 that I can send you when I get home in a couple of weeks. Would that help? It gives the information to do tests etc.
I am also on the Yahoo MK site. That may be a better place to share as I am not sure about this site.
-Janet
SOURCE: needle clamp fell off. got a new one, but need
I have an XL6452 and the same problem. I figured out that you can use a tiny screw driver (or an allen wrench might work). I tried using the screw that tightens the needle but it didn't seem to work. The screw looks like it just a hole. It took a lot of turns to get it loose enough so you can put it on. You will see it come out.
Once you get it on you can tighten it.
SOURCE: I have a Necchi Supernova Julia sewing machine, and unfortunately
I had what I thought was the same problem with my Necchi Supernova Julia 534. Turns out it was the needles. Buy a new package that you know are right and try them.
