Hoover S2105 Slider Bagless Stick Vacuum Logo
A
Anonymous Posted on Sep 10, 2014
The red light keeps blinking while I have the charger plugged in, is this normal?
  • Official Brand Answer 155 Answers
  • Posted on Oct 30, 2014
Hoover
Level 0:
Answers
155
Questions
0
Helped
93063
Points
375
Hi! If the light on the charger is blinking this can mean an issue with your charger adaptor. Check that the charger is still warm. If so, unplug the charger for a few minutes and plug it back in. If the light is still blinking your charger adaptor may need to be replaced. Hope this helps!
2answers
V6 Red light blinks 32 times
Your Dyson may not have been connected to the charger correctly when last put away.
1helpful
There is a red blinking light on my dyson when I first plug it in to be charged. Please advise
First, I'm not a Dyson Tech, but I have worked on battery operated recharge devices.
* Is this new or second hand? Most chargers for any device will blink red if the charge on battery is so low that the charger will not recognize the battery. If so (old battery) then got to get a replacement (New) battery.
Aloha, ukeboy57
FYI there is a slight possible fix for this old battery. But it's a long shot. Check on you tube on your specific battery "save ________ dead battery." (you force charge it to a reasonable level. But you didn't hear it from me ;-)
@ in one dirt devil light keeps blinking
Hi! The model number you provided M085845 is a corded vacuum that does not need to be charged. If you have a battery operated product, the indicator light will begin to blink after being plugged in for 12-14 hours or more. Try unplugging the charger for a few minutes. Hope this is helpful. If you still have questions please reach back out to us here of Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil. Thanks!
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
5helpful
2answers
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
