Water and ice will not dispense
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
SOURCE: Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
SOURCE: My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
SOURCE: Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
