What kind of oil grease goes in a. Hm1301 makita jack hammer
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
SOURCE: A friend of mine recently
If this was a new unit, it comes with the proper amount already in the gearcase. You might need some for the hammer bits (a small amount of lithium grease) but other than that until the tool needs repaired you should not have to add any.
SOURCE: Where do I ad oil to a makita hm1500 demolition
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
SOURCE: makita jack hammer 1500 service manual
Go to the Makita website at http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in the search box at the top, click on the arrow and you will be presented with any models with similar numbers. Select your jack hammer and you will be able to download the manual and parts breakdown.
SOURCE: Electric kango dem. hammer needs lubricant is it oil or grease Mod. 800
A basic lithium grease should be ok. Get it from the car shop. nothing too heavy.
