Can you provide an element or a module for a Dacor ECC 36 cooktop? or a EM2LFB
SOURCE: Dacor cooktop Model # SEC30-1C
is this a smooth top? glass? if so gently scrape with a razor blade yes a razor blade. then buff with cerama bryte or comparable cleaner available @ walmart or home depot etc..
SOURCE: Need part# 786106 (coil element module) for Whirlpool cook top RC8920XRC
I have the part. New in box.
SOURCE: The dual element on my electric smooth-glass
Hi, my humble advice to you is to call in the repair man to come and carry out a check and properly diagnose what the problem is.
You might be lucky to have a fuse problem which th repair man will find and replace it and if the element goes beyond the fuse issue, the repair man will be in the best position to determine if you are to purchase and install a burner module or buying a new cooktop...
So call in the repairman first.....
SOURCE: 36" Wolf induction cooktop cannot get past show
To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for five seconds. After the cooktop is locked, press and hold the melt touch pad for five seconds.
SOURCE: Replacement solid elememt burner unit for my Dacor ECC46 electric cooktop
Have you try this link
