Bought a technika remote control for my technika tv but it wont turn the tv on
If it is its original remote control, without any adjustments, it should work with it. Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
SOURCE: technika sky code volume needed 42-502
the code for the new sky hd remote for my technika 42 -502 plasma tv that controls the volume is 0206 works ok now
SOURCE: I have been given a technika flat screen tv
You should try codes for Funai, Symphonic, & Sylvania. Some Tecknikas are same as some of those. At least in my Comcast cable box remote code listings.
SOURCE: I have bought a Technika TR41R remote, i have no
the code for a technika tv is 1014.hope this helps...
