I push the knob in and out and it starts again.
SOURCE: Error code
My problem was simply that the screens where the hoses connect to the washer were clogged with rust from my well water. I cleaned them and we're back in business.
SOURCE: nf pops up on the screen & the washer stops
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
SOURCE: I have a Maytag Model MAH8700aww washer
SOURCE: Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
thanks
