Question about Apple iPhone 3G
Error 1015 iphone 3g ,stuck in recovery mode
The iphone is in recovery screen stuck,it gives error code 1015,on itunes
    New Friend:
The easiest way to fix iPhone recovery mode screen is to use the free tool called ReiBoot. i used it before and it worked perfectly for me. What's more, it is very easy. No need to connect to iTunes and hold any button on iPhone. You can try it if needed.
Tenorshare ReiBoot
Posted on Sep 17, 2014
  • Haywood Alex
    Haywood Alex Dec 05, 2019
    Tenorshare ReiBoot is a handy iOS repair utility that lets you easily access and exit the iPhone recovery mode without losing data. If your iPhone XR / XS / X / 8/7 / 7plus / 6s / 6s plus / 6 / 6plus / 5s / 5 is in recovery mode or in DFU mode when upgrading to iOS 12/11, this iOS system repair Tool the best software to get iOS back to normal with an intuitive user interface. In addition, even the solution is supported by more than 50 issues that occur on iOS without data loss, including the white Apple logo, the reboot loop of the iPhone, the black iPad screen, and iTunes errors, etc.https://hdlicense.com/reiboot-crack-regi...
    New Friend:
  • 49 Answers
Chances are the phone has at some time been Jail broken,
your best option is to use a program like Redsn0 or blackra1n these will do the job, and make sure your itunes is the latest version
good luck
Posted on Sep 15, 2014
3 Suggested Answers
6ya staff
SOURCE:
ashlocked
Christopher Lozada
  • 1140 Answers
SOURCE: After update my iPhone 3GS
My point of view of ERROR 1015 is when the baseband and the firmaware does not match when updating to itunes,it will result on this error like this
http://imageshack.us/photo/my-images/594/error1015.png/
(please copy and paste the link if you can't directly seen the image)
* To solve this problem,download this software and it will fix the problem
http://www.uploadmb.com/dw.php?id=1311481464
* Follow the illustration guide.
1. under iREB menu click "iphone 3gs"
2. under recovery mode loop fixer / shsh blobs grabber menu click "set auto-boot (fix 1015 errors/recovery loop)
wait until the progress is done...
Please view this link to make it clearer.
http://imageshack.us/photo/my-images/843/71519345.png/
http://imageshack.us/photo/my-images/38/23727797.png/
Now you can proceed JAILBREAK & UNLOCKING procedure.
Hope this method helps, Thank you for visiting FixYa...
Posted on Jul 24, 2011
Matt jones
SOURCE: IPHONE ERROR 1015
Try holing the Home button and ON/OFF button at the top at the same time for 30 seconds. It should do a restart and everything "SHOULD" work I'm not 100% positive
Posted on Sep 01, 2012
How do I Fix iPhone Error Code 1015?
iTunes error 1015 is always along with the "plug into iTunes" screen stuck on iPhone. Indeed, that is the common error "iPhone stuck on recovery mode". Easy and quick way to fix it is to use the Re Boot. ... The error is that iTunes recognises a corrupt version of it's ios and will not complete signing.
Mar 16, 2018 | Cell Phones
Error 1015 in iTunes iphone 3g Model no a1241...
  1. Disconnect the USB cable from your iPhone, but leave the other side connected to your Mac or PC
  2. Launch iTunes
  3. Press and hold down the Home and Sleep/Power button on the top of the iPhone to turn off the iPhone
  4. Press and continue to hold the Home Button while you reconnect the USB cable to your iPhone, this will cause the iPhone to turn on
  5. Continue to hold the Home button until an alert message in iTunes informing you that an iPhone in recovery mode has been detected. Your iPhone is now in recovery mode. If you have not launched iTunes, you will see the familiar screen of the USB cable pointing at the iTunes logo signaling to connect the iPhone to iTunes to start recovery.
    Once you're in recovery mode, you can either restore the iPhone or adjust the firmware as necessary.
    After restoring or upgrading firmware, your iPhone will automatically reboot and exit recovery mode on it's own.
Sep 05, 2015 | Apple Cell Phones
Iphone stuck on itunes recovery mode
Your device stucks in DFU mode, you can try some 3rd party ios data recovery tool to exit recovery mode. Follow this guide to have a try DFU Mode How to Enter and Exit DFU Mode of Your iOS Device
Aug 12, 2014 | Apple iPhone 3G
IPHONE ERROR 1015
Aug 24, 2012 | Apple iPhone 3GS Black (16 GB)
After update my iPhone 3GS (unlocked and updated to the Ipad firmware) via Itunes it comes wit the error code 1015 and is in permanent recovery mode. Tinyumbrella cannot fix the problem
Jul 24, 2011 | Apple Cell Phones
My iphone 3g is on restore mode it goes to restore nearly completed then error code 1015 comes up at the end
Download latest itunes. Use only itunes and update it with original software.
Jun 03, 2011 | Apple iPhone 3G
My iphone is unable to update and restore and I got error code 1015.
This usually happens when you hve problems downgrading firmware or jailbreaking.
Here is a guide to fix it.
To fix this error, you will have to make a couple of changes in your system's "host" file, by pointing it towards Cydia server instead of Apple's. Also this is not it, you may also receive another error during restore: 1004, or 1015 from iTunes saying: "The iPhone [you name] iPhone could not be restored. An unknown error occurred (1004)". The following step by step instructions will guide you on how to fix these errors so that you can restore any of your new iOS devices like iPhone 4 or 3GS to iOS 4.0.1 successfully.
Step 1: Download the required iOS 4.0.1 ipsw firmware files from here.
Step 2: Put your device into DFU mode (not recovery mode).
  • Connect your iPhone to your computer.
  • Turn iPhone off.
  • Start iTunes.
  • Hold Power and Home buttons together for 10 seconds or so.
  • Release Power button but keep holding the Home button until your computer recognizes a new USB device.
  • iTunes will now recognize your iPhone.
Note: Your iPhone screen at this time should be blank (black in color), if not, then you are most likely in Recovery Mode, not DFU mode.
Step 3: Before you proceed, you must make sure that you have your SHSH blobs saved on Cydia for the firmware version you restoring or downgrading to. If you don't have your SHSH files saved, you cannot downgrade or restore to iOS 4.0.1.
So now, what we will do is to trick iTunes into thinking that it is watching Apple servers, while in real, we are going to change the address to Saurik's server.
  • Navigate to C:\Windows\System32\drivers\etc\ and locate "hosts" file.
hostsfileinwindows.png Mac OS X users can get to "/etc/" directory by going through "Go -> Go to Folder" from Finder.
  • Open this "hosts" file in Notepad (for Windows) or TextEdit (for Mac OS X) and add this
74.208.105.171 gs.apple.com line as shown in the screenshot below:
21.png Now simply save this file and you are good to go!
NOTE for Windows 7 and Vista: Start "Notepad" with Administrator privileges by right clicking on "Notepad" app, and click on "Run as Administrator" option.
NOTE for Mac OS X: Make sure you have full read and write access on your account when you are saving the host file. If it still throws permission error, simply copy the host file to desktop, make the required changes, and then replace it with the original file in "/etc/" directory.
Step 4: You will now have to restore your iPhone to the firmware you downloaded in Step 1. Click on your phone icon from the sidebar in iTunes. Now press and hold left "alt" (option) button on Mac (Left "Shift" button on Windows) on the keyboard and then click on "Restore" (Not "Update" or "Check for Update") button in the iTunes and then release this button.
itunes.png This will make iTunes prompt you to select the location for your downloaded firmware file. Select that ipsw file and click on "Open".
Step 5: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps. Be patient at this stage and don't do anything silly. Just wait while iTunes installs firmware on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. Now at some point, iTunes will probably throw 1004 or 1015 error at you. This is normal, just ignore this error as the firmware has already been successfully installed on the device.
iphone42.png Step 6: Your iPhone at this point will be stuck in Recovery Mode, showing that "Connect to iTunes" screen. To exit your device from Recovery Mode, download this program called TinyUmbrella (Windows / Mac). Run it and the click on "Kick Device Out of Recovery" button. Your device will now restart normally.
iphone43.png This is it, you should now be able to jailbreak and unlock your device.
Feb 23, 2011 | Apple iPhone 3G
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 19, 2011 | Apple iPhone 3G
I have iphone 3g version 4.1 i wont to unlock it
You can try to use "tinyUmbrella" to see if cydia has you ssh on file..
tinyumbrella website
once you start the software you click the button save my ssh..
once it's done processing you can click on start tss server
This tss server will allow you to bypass itunes server which restricts downgrading firmware...
Once Tss server is running you can start itunes
once itunes detects your iphone shift + click on restore
Select the iphone 3g 4.0.1 firmware (goto http://www.felixbruns.de/iPod/firmware/ to download this)
Once it restores fully at the end it will give itunes error '1015'
dont worry..
Install Libusb if you dont have it..(Click here)
after installing libusb just use this program.. ih8snow
Click on "Fix recovery mode loop"
Click on yes to "do you have libusb installed??"
Select iphone 3g from the list
your iphone will reboot..
now you can first activate it ..
then you can use safari to goto Jailbreakme.com
slide the slider at the bottom...
it will download cydia
when cydia is installed you have to add "repo666.ultrasn0w.com" as a source
Its a zero "0" in the sn0w not "o"...
Search google how to add new sources.. to cydia..
Once you are done installing the application inside the repo666.ultrasn0w.com source your phone will be finally unlocked..
Of course easier way out would be to pay someone who knows how to do this..
regards
Oct 21, 2010 | Apple iPhone 3G Black Smartphone
My 3gs iPhone is stuck in restore needed/emergency call mode. I've tried to sync to different computer...same problem. iTunes does not recognize and then when I try to restore it gives a 23 error or 2001...
Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:Use iTunes to restore the device.
If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup. See this article for more information.
Jan 17, 2010 | Apple iPhone 3G Black Smartphone
Apple iPhone 3G Logo
156 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
