HAVE NOT USED THIS TV FOR A WHILE, THE PANEL LOCK WAS ACTIVATED BY ACCIDENT NOW ONLY THE STANDBY LIGHT IS ON WHEN THE TV IS POWERED UP.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: Tv locked; can't unlock with remote even though we have the original manual
I had the same problem with my hyundai hf2215 tv. Hold down the DISP button on the remote for at least 30 seconds and the lock comes off and tv returns to normal.
SOURCE: The tv will not turn on with either the remote or
I own the same TV and had the same problem.
It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them.
Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
SOURCE: GOODMANS GTVL26W26HDF - no Remote control/child lock is locked!!
hi just got a goodmans x pro witout the remote any chance you could let me no how to turn it on as its just on stand by now thanks
SOURCE: no standby redlight, picture or sound.no effect
Power supply board is dead.Replaced the power supply board will solved this power problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
