After washing 'OE' appears on display and does not drain - spinn - rinse etc please send manual ! thanks Doris
SOURCE: FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
SOURCE: Kenmore front load washer won't drain
Remove the bottom panel under the door to access the drain pump. Make sure the washer is unplugged before servicing the pump. The pump will be located under the wash tub in the front of the washer. There should be a small access cover that can be unscrewed to access the inside of the pump. If not, remove the inlet hose to access the pump impeller. HINT: Pull the drain hose from the standpipe and use a shop vac to pull a vacuum on the drain line. This will pull any remaining water out of the drain lines and wash tub. This will minimize the amount of water that spills out of the drain pump when you remove the access cover.
It does not take much to damage this small drain pumps. If you clean the pump thoroughly and it still exhibits drain problems, the manufacturer recommends replacing the pump.
If you require additional assistance, let me know before you rate the solution. I hope this helps you.
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
SOURCE: "OE" error message appearing at end of rinse cycle before spin
on the front lower left there is a panel. Pry it open from the top. Unscrew the large black round cap. Be prepared for water to rush out. There is a trap to clean out. To the left there is a rubber hose with a plug in the end. Remove plug and see if hose is clogged. Clean it out. Replace and it should run. If not, try blowing through the discharge hose in the back to make sure all is clear. If not??
SOURCE: what does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error.
This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
Hello & Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
other questions.
Kevin
Hello &
Welcome to FixYa
other questions.
Kevin
Hello &
Welcome to FixYa
filter located inside the front bottom for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
