Question about Powermatic 2 Electric Cigarette Injector Machine
HOW TO REPAIR POWERMATIC 2 CIGARETTE MACHINE
WHEN I PULL DOWN THE HANDLE THE SPOON GOES IN AND OUT SEVERAL TIMES BEFORE STOPING IN A DIFFERENT SPOT EVERY TIME
    New Friend:
The machine came on when u pushed level down the part u put tubes on was not sliding out i took apart need help putting it back together properly
Posted on Jun 27, 2015
    New Friend:
  • 16 Answers
That's right, if it is within it's warranty period, return it. On the other hand if it is out of warranty and you are somewhat mechanically inclined, you can open it up. The screws are in the bottom of the unit under the feet. Take them out, open it up and you will see there are connector(s) on the circuit board you see 1st. Unplug the connectors, clean things up as you go also. Do take note of the orientation of the connectors. Once that board is out, you will see another smaller one under it, and the motor w/mechanical parts attached. The small circuit board is the optic that senses the position, likely has tobacco dust obstructing it. Either remove it and dust it off, or use some canned air and blow things out. While in that far, check the mechanical parts for wear, they should not be too loose. There is play in them, but not sloppy. Hope that helps :)
Posted on Dec 19, 2014
  • 2 more comments
  • Roy Bommarito
    Roy Bommarito Jul 16, 2018
    yup I know 2014 and now it's 2018! Bought mine in 2014 and now HAD trouble with it 4+ yrs of service. Now it's back together and working like new. THANK YOU!
  • brainstorm21
    brainstorm21 Apr 23, 2019
    Yes, helpful information
  • Daniel Karkusiewicz
    Daniel Karkusiewicz Aug 28, 2019
    I'll see if that helps with the trouble I'm having where the tube holder releases too soon and the cigarette doesn't get filled to the filter
    Unfortunately, that didn't do it. Now it releases even earlier than before
    New Friend:
    Problem Solver:
  • 9 Answers
Sounds like an electrical problem. Return it the powermatic 2 has a 1 year warranty.
Posted on Dec 15, 2014
Video on how to use this strap wrench
There are several different types of strap wrenches, the picture is what I have. Sorry I don't have a video. I use it to remove oil filter. The loose end goes through the hinge under the back end of strap. Place around oil filter, snug up by pulling loose end then the wide part of the handle bits down on the strap so you can put torque on it. Depending if your tightening or loosening, you flip the handle.
YouTube has videos, don't know if they have a video for using wrench strap? Like I said many different types of wrench straps.
Jun 28, 2017 | Cars & Trucks
Loud knock in motor 1995 883 HD
TIME FOR A TEAR DOWN START EASY CHECK TOP END FIRST, THEN YOUR GOING TO BOTTOM END. I LIKE TO USE I PRY BAR OR LING BIG SCREW DRIVE, PUT HANDLE IN YOUR EAR AND PLACE ON THE SIDE OF ENGINE IN SEVERAL SPOTS TO FIGURE OUT WHERE THE SOUND IS.
Feb 22, 2017 | Harley Davidson Motorcycles
Schematic of carburator on Model No. 917.776740 Briggs and Stratton engine on a 675 Series on a Craftsman Wheeled Weedtrimmer.
remove the water from the fuel tank
\ put in about 2 table spoons of methylated spirits in to fresh fuel in the tank , use a primer bulb and pull several times to get the new fuel into the carby
The methylated spirits breaks the water down so that it goes through the jet
Jun 11, 2016 | Craftsman Garden
you are cars and trucks catagory and nothing on a car or truck has a spoon
IT is confusing because you never bothered to give any details like , make , model , year , type of equipment etc
as posts are not linked post again with the details
May 24, 2016 | Cars & Trucks
Handle is stiff to operate
remove trim to expose valve, apply stem-grease to valve with fingers and re-assemble. turn valve on and off several times. like new
Dec 12, 2012 | Hamat 3-2810PC Everest Pull-Out Kitchen...
Should knives/forks/spoons be loaded with blades, tines,bowls down or up in dishwasher? When ready to load knives/forks/spoons in the dishwasher, should you load the utensils with the handles at the...
I always put the handles down in hope of the spray hitting the business end better.
I'm sure there are arguments for handle up too, but I put the handles down.
lp
Jan 08, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Hard to pull up handle
Are you asking about faucet handle or pop up drain . If you are referring to faucet handle the easiest thing to try first is to remove center cover from top of handle. It's the one with the moen insignia or name on it. These are usually just a friction fit so use a small blade screwdriver or knife blade to carefully remove cover. There is a screw that holds handle on cartridge. Remove screw and gently remove handle by pulling up. If you have not shut off water supply valves this will open valve and run water. Push down on carteidge stem to shut off water. Use a penetrating oil such as WD-40 and spray around cartridge.Allow a few mins. then pull cartridge stem up and push it back down several times spraying with penetrating fluid several times. You can move stem by gripping with pliers. This should help free cartridge . If this helps you can save on service call. Reinstall handle with screw and center cover. Hope this helps. Thanks
Nov 12, 2010 | Moen 1 Handle LavatoryWith Drain Assembly...
How do you remove the interior door panels to access the window motor ? these are not your normal clip type. thx, Shawn
have replaced the crank arm in my 96 Grand Am SE.
1. Remove the mirror from the door, there is a snap on cover be careful and unpop it off from the 3 plastic slot snap-in holders this will reveal 3 bolts. Unbolt the nuts and carefully take the mirror off the door.
2. The mirror is still holding on by the inside remote or manual lever for the mirror. Be careful not to tug or yank on it as there is a small plastic ring grommet on the inside of the door located under the leather or what ever the interior material is. It is a 3 prong plastic inset. The best way to take this off is to get a ty-wrap around the ring and tighten this up until you can slip the chrome lever down thru the hole. If you break the plastic ring you will have to order on thru a dealer to replace it..
3.The door has several plastic retainer clips shaped like a screw with ridges along the sides the head of this clip inserts into the back of the heavy cardboard and when pushed into the metal holes of the door itself will lock it in place. Unfortunatly, evertime I have taken a door of any kind off, you will break at least 3 to 5 of these plastic fasteners. You might find these at your local car retail stores, but again, these may have to ordered from a gm dealer. So...anyway if you tug on the inside door panel you will get the idea that there are several of these holding the cardboard to the metal. Try to use a door spoon to pry these clips away from the door. sometimes I had to use a large blade screw driver, but if your careful you can do this without much trouble.
4. The inner door panel will be loose at this time. Now for the fun part...getting the door handle off. To make things much earier, go to the local car retail store and ask to buy a door handle spoon, it should run you about 6 bucks. The handle is secured with a C clip that is holding the door shaft onto the inside mechanism. With the spoon you can use the U or open part of the tool and push the spoon around the handle till you feel it "kinda" slip into the C clip and while gently pulling on the round part of the door handle, [not the handle with the knob, as it might be twice as hard to remove] gently push the tool into the clip, the clip will give way and the handle should pull off easily. Do Not try to slam the tool into the clip, you'll loose it, and have to buy another. Al it takes is a gentle but firm push and you will feel it give.
5. Oh yeh...make sure the door is in the unlock position when you do this. Things will go easier. This is just a suggestion.
6. On the door puller [the handle that you close the door with] there is two screws, use a #2 phillps driver and remove them.
7. Now remove the handle. If you look inside the , thru the removed door handle you will see the power harness for the door lock unlock switch. This is a square hole lock type setup. Use a smaller blade screw driver and gently upen on side at a a time and then the other. This might take several tries on each side of the switch. do not force or try to pry the harness pnenolic snap-on to fast or in on motion, as you will break it or bend the snap-on so that when you put it back together it will fall of the lock switch.
8. If there are power windows and seat switches use the same procedure for each of the swtiches, remember do not force and of these. You might even destroy the harness and pull the wires out of the snap-on harness, again, this is NOT what you want to do, be patient.
9. The sliding autolock now has to be removed, the automatic back and forth lock unlock mechanism. You should be able to slide to cardboard panel out and forward enough to slip it off away and free from the panel.
10. Another thing make sure the window is down when you start this procedure, I keep forgetting about the small stuff, but it makes a difference.
11. Now you have to remove the retainer rubber from the outside part of the door. I have tried to remove this rubber part and ruined everyone of them, as the retainer clips are usually rusted or will break when you try to free this away from the door. I have used plyable non-drying silicon to put it back on, [oh yeh...this is why you have to revove the mirror, as it part of this rubber assembly]. When all of this is accomplished you can grab each side of the cardboard innder panel and lift straight up and out of the window jam. It's approx a 2 to 3 inch lift to free it from the door.
12. Hope this helps. For me [alone] with no help and being 62 yrs old and tuff to move around, took my 2 hours to remove, replace the inner window crank [ which is another horror story], and 2 or so hours to put back together if you have taken all the precautions and pre-bought all the replacement parts prehand. So if your young and full of ambition and follow instuction well [ I hope these are good enough instuctions] this job should take you are 1 to 2 hours to remove the door panels.
Aug 12, 2009 | 1996 Pontiac Grand Am
Clean my car seat
Those pieces WILL snap out, it just takes a bit of effort. Both my son and the boy that I nanny for have this car seat and I have taken them apart for washing the cover a couple of times. Just make sure to remember where everything goes back to.
If you're having difficulty prying them up, try using two spoons. Wedge either the handle ends or the spoon ends under either side and use them to leverage the piece up.
Hope this helps!
Mar 23, 2009 | Eddie Bauer Deluxe 3-in-1 Convertible
Powermatic 2 Electric Cigarette Injector Machine Logo
7,434 people viewed this question
Top Powermatic Cooking Experts
Frank Hunter
Frank Hunter
Level 1 Expert
ray gallant
Are you a Powermatic Cooking Expert? Answer questions, earn points and help others
