I have used a right angled lens to shoot street photography. This is based on a mirror/periscope system and the result is a mirror image ie. writing back to front/ cars on the wrong of side of the road etc. I need to 'flip' the image to correct this.I have tried pressing Ctrl/shift/H to no avail.I am told that Picasa 3 upgrades automatically so I think that I have the latest update. Please advise.
Launch the Picasa application using the desktop or Start menu shortcut icon. Use the folder structure on the left side of the window to locate the image that you want to modify, and then double-click the image to open the editing interface.
Press and hold the "Ctrl" key.
Press and hold the "Shift" key.
Press "H" to flip the image horizontally.
Click the "Back to Library" button at the top of the screen to return to the image library. Picasa remembers the changes to the image automatically.
SOURCE: no sound and dvd does not work
THE PROBLEM IS WINDOWS VISTA HOME BASIC - UPGRADE GETS RID OF PROBLEM
SOURCE: Upgrade processor on ALI 1541 motherboard
May need to be configured in the Bios, but also some older boards had processor adjustments on the motherboard, either with a block of little white dip switches, or with jumpers that you remove or replace depending on the processor. Some times the settings for the processor are printed on the board too. Are you sure the motherboard can take a processor up to 500MHz.
If you don't have the manual for the motherboard have a look on it for the make and model number and search google for it. If it is available it will probably be an Adobe pdf file so make sure you have Adobe's Acrobat reader.
SOURCE: Windows XP2 to Windows XP3? HELP!
Well I can tell you your issues with All programs and Control Panel not displaying are only caused by 2 things. One is a corporate IT department preventing you from accessing that functionality of your system and two is a virus known as "Virus Alert". Check out next to your time and instead of AM or PM it will show "VIRUS ALERT!!!". Download Dial-a-Fix (http://wiki.lunarsoft.net/wiki/Dial-a-fix) and run the Fix Policies in the bottom left hand corner. This will fix your control panel and your ability to install/uninstall programs. The All Programs is a bit trickery but let me know if you want to try to fix it.
SOURCE: NTRL is compressed Press Ctrl+Alt+Del to restart
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Please rate this fixya
SOURCE: Acer desktop T180 is stuck on verifying DMI pool DATA..
verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
