Question about Hoover Washing Machines
Hoover 750 lc heavy duty macking noise whene spinning dry
Running okay but too noisey whene spinning on high speed
    Problem Solver:
  • 9 Answers
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
Posted on Sep 13, 2014
Anonymous
SOURCE:
Anonymous
SOURCE: Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
Posted on Jan 28, 2008
Anonymous
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
Posted on Nov 14, 2008
Anonymous
  • 113 Answers
SOURCE: Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Posted on Dec 16, 2008
Anonymous
SOURCE: Loud dry sounding spin cycle
I had the same problem with mine. The noise was verry loud towards the end...2 years I was a happy camper with my top of the line Cabrio, and then started to do the noise, a friend who work on washers told me that it was the transmission and to let it bust it self and then fix it. I have a home service warranty that covers the washer and they send a tech to fix it, he fix the problem with the transmission but now I have a problem of UL Unbalance Load all the time and I have to be moving the cloth around and move the knob to drain and spin all the time to get the the machine to drain the water. good luck with your problem
Posted on Jun 26, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
I cannot choose max spin. When I hit the spin
some lower cycles wont allow high speed spin, try heavy duty.
Nov 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washer will barley agitate or spin and make a
Try high speed only (cycles like cottons, heavy duty, etc. This happens when the low speed on the motor is not working. If high speed is working for you, the olny way to make the lower speeds work is to replace the motor.
Your part number is WH20X10019 and it's expensive...
Oct 20, 2009 | GE WBSR3140DW Top Load Washer
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Washing Machines Logo
171 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
