Lands Phones Logo
A
Anonymous Posted on Sep 13, 2014
How do i delete a number from the already stored numbers on the phone?
I have stored the wrong details and now want to delete them
Ritesh Shah
Level 2:
  • Expert 43 Answers
  • Posted on Sep 13, 2014
Ritesh Shah
Expert
Level 2:
Answers
43
Questions
Helped
27356
Points
101
Goto Contacts list and press the contact you wish to delete twice and a menu will show an option to delete. Select delete and the contact will be deleted.
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Jan 20, 2008
SOURCE: change/add #'s in Memory
Find your model number and then click this link to download the manual
Manual page
Anonymous
  • 65 Answers
  • Posted on Feb 25, 2008
SOURCE: delete old phone number on auto dial and add new one
go here and download users manual by clicking on file name
http://service.us.panasonic.com/operman/findmanual.aspx?model=KXT7630
srivatsahg
  • Posted on Jun 17, 2008
SOURCE: To store phone numbers in Memory
I found it out eventually ...
Assholes make this site free for everyone ... Spread Humanity instead of making loads of money.******* Capitalists
Anonymous
  • Posted on Oct 30, 2008
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Jun 26, 2009
SOURCE: Display most recent Caller ID telephone numbers not old ones
You have a 7730 PHONE. The system is not determined, but in analog going forward it could be a TA-624/824 or TAW-848.
If you have a TA system, it requires programming http://www.fixya.com/support/t2436730-caller_id_stoped_working_dont_know_clear
Carl
1helpful
I want to change my nsfas cellphone number
FIXYA is a free online service and is not connected to any university or government office.
Here are instructions for changing your NSFAS cell phone number.
How to update your cellphone number with NSFAS
Students who wish to change their contact details can do so by:
Login to my.nsfas.org.za
On the already registered tab
Enter your username and Password Click on sign in button
Click on my personal details
Go to the cellphone number section
Delete and remove and type in the new
cellphone number Click on update details
OTP will be sent to your new number
Enter OTP and submit
Number should be successfully changed (if a duplicate number exists student will get an error message)
Students who are unable to change their details online can use the manual process by emailing certified copy of their green barcoded ID or smart card, and a completed affidavit specifying that they have changed their cell phone number; with the new and old number listed to [email protected].
You may wish to verify your change by calling NSFAS in South Africa on a toll free number:
NSFAS's TOLL FREE Call centre is 08000 NSFAS (67327)
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
8helpful
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
1helpful
2answers
MY SAMSUNG S3500 ALREADY PUK LOCK PLEASE RECTIFY
r If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted
How to delete a stored program in KX-T7730?
Stored program? If you mean stored speed dial or commands under the buttons, it depends on the system. Some use the TRANSFER to clear the number, and some just use storing an empty number over it. If it's a button on the left and a TA system, press PROGRAM, the button, 2 STORE and it will erase. If it's a button on the right, then PROGRAM, the button, TRANSFER STORE works.
I have no idea why, except the right buttons already have 2 assumed.
It's a Panasonic :-)
Carl
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Nokia 7310 Supernova. If someone calls cant see their name!
well, simple problem in your device.
You must have copied each number with two names or there may be double entery inside phone.
possibly problems
  • Double entry for single number
  • same contact in phone and sim
  • missing country code (ex. +91 xxx) in special cases
Solution:
  • take one other phone, and delete that number from your phone (sim n phone both memory) after deleting that contact details, misscall from working phone to your phone, and store that contact in ur phonebook
  • delete all contacts and add one time only. make sure no double copying
  • add country code before number
Tht's it, solution is as simple as 1 2 3
www.softzonelab.com
Cannot edit stored phone numbers
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
2answers
Sony Ericsson K610i mobile phone
I had the same problem... it was solved for me by going into
Menu -> Calls -> More -> Delete All
I think the problem was that the missed and other calls were stored in the provider's server... and deleting each entry from the list was not deleting them from there, but instead just deleting the entry from my phone.. anyway... now it saves and shows the missed calls.
I hope this helps...
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
