It seems like you're experiencing issues with your Pro-Form 580X treadmill. Here are some troubleshooting steps you can try:
Safety Key: Ensure that the safety key is properly inserted into the console. Treadmills typically have a magnetic safety key that must be in place for the treadmill to operate.
Circuit Breaker: Check if there's a circuit breaker on the treadmill. If it has tripped, reset it. This is often located near the power cord entry point.
Power Source: Verify that the treadmill is properly plugged into a functioning power outlet. Test the outlet with another device to make sure it's working.
Calibration: Some treadmills require periodic calibration. Check the user manual for instructions on how to calibrate your specific model.
Check for Obstructions: Ensure that there are no obstructions or debris around the belt or underneath the treadmill that might be preventing it from moving.
Lubrication: Treadmill belts may require lubrication. Consult your user manual for guidance on how to lubricate the belt properly.
Control Panel: If the control panel buttons are not responding, it could indicate an issue with the console or wiring. You may need to contact Pro-Form customer support or a technician for further assistance.
If none of these steps resolve the issue, it's advisable to reach out to Pro-Form customer support or a qualified technician for a more thorough diagnosis and potential repairs.
follow this steps and fix it. God bless you Plug Treadmill into wall outlet and press START. Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR" Is red SERIAL lamp on the motor control board lit? Is the yellow RLC lamp on the motor control board lit? 1. Unplug the treadmill from its 2. Wl alk on the belt manually. (push belt) 3. Does the yellow MOTOR lamp light while pushing? Is yellow MOTOR lamp on the motor control board lit? 1. Loose wire connection to motor, capacitor, or choke. 2. Loose brush holder screw on motor. (Check Both) 3. Failed drive motor. Part # 70014 (110V), 70125 (220V) NO YES NO YES 5.1 5.2 5.3 5.4 5.5 NO 1. Check wiring harness connection between upper and lower board. Part # 70083 2. Replace display board. Part # 70076 YES Enter Open Loop Speed mode: WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE. 1. Turn off the treadmill. 2. Press FAST and START simultaneously and release both buttons once the display lights up. 3. Hold the fast button until the display reads 99. Short in capacitor, motor, or motor control board. NO Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -) terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99. Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill. If you are not getting dc volts out of the lower board, replace it. If you are measuring the proper dc voltage out, replace the drive motor.
please LUBE the deck belt+rollers bearing. see the video attached. If the problem persist TIME to replace the old deck belt board. This happen because the lack of maintenance schedule in LUBE. God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor
You must check the fuses+breaker inside from machine +breaker from house, of course check power cord if there are some loose cable, or another loose cable inside from the machine, or broken cable. Tight any cable inside.!
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
