Question about Nextbook Premium 8 Se Android
How do I connect my Nexbook 8 to the internet on my laptop
Following instructions butI can't get itto work.
    Sergeant:
  • 399 Answers
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Posted on Dec 22, 2014
6ya staff
SOURCE:
I got a nextbook NX16A10132s ps, for Christmas and I don't have the receipt for the activation code. What can I do
if bought with credit card you can go back to store for a copy . nexbook can give new code.
Jan 28, 2018 | Nextbook Tablets & eReaders
Can't connect to internet for kindle paper white reader as I can't remember my internet password
The password may be on a sticker on your wireless router. Unless it as changed from the default password, then you'll have to go to the manufacturers website and find the factory reset instructions for your router.
Jul 17, 2016 | Tablets & eReaders
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
How do I get it on my wifi network? it keeps telling me it is avoiding the network because of poor internet cinnection.
If you have poor internet connection problem with your WiFi, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Dec 25, 2014 | Tablets & eReaders
Need to download iOS 8.0.1 on my apple ipad keeps telling me it failed because I am not o internet, but I know that I am connected to the iternet what is wrong?
if you have laptop/desktop computer you can sync the iPad with iTunes and download iOS 8.1.2 there:
Upgrading iPad to iOS 8: Through iTunes 1. Backup your iPad
Open iTunes. Select your iPad in iTunes and click Back Up Now.
2. Restart your iPad and your Computer
3. Download and Install the Update
Go to iTunes -> Select iPad -> Check for Update -> Click Download and Update
Whichever method you choose, the process will take quite some time to work depending on how much free storage you have on your iPad, your internet connection, and how Apple's servers are doing with upgrades. Occasionally, Apple will either not let you download the upgrade or it will fail. For iOS 8, you must have an iPad 3 or newer. This does not work with the original iPad - if something goes wrong, restart your device, and try again.
How to Upgrade to iOS 7 on an iPad or iPad Mini
How to Install iOS 8 When Your Device is Low on Storage need-download-ios-8-0-1-apple-ipad-keeps-u3wnnnxjlb3ct0ebur4t0xqn-1-0.jpg
Sep 26, 2014 | Apple iPad Tablets & eReaders
Nextbook 8 cant get wifi to work now - worked before??
Hi there
You have checked that you are joined to the network via the router?
The laptop most certainly is.
Try disconnecting the router and turning the Nextbook off for a few seconds, connect the router on again and open Nextbook.
Join the network again and put the password in.
This way of connecting has worked for me. Hope it will for you.
May 06, 2014 | Nextbook Premium 8 Se Android
Battery only holds for 3 hours despite following all instructions. that's 3 hours of reading time with wifi turned off
I would replace the battery then, if the battery isn't removable then you could buy a used device on eBay for $30.
Dec 14, 2013 | Nextbook Premium 8 Se Android
Nexbook
please provide actual brand and model # for better help
Jun 15, 2013 | Tablets & eReaders
I cant connect to internet but i installed the necessary driver
To connect to the Internet you need a few extra things aswell as a network card.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
May 18, 2011 | IBM ThinkPad X41 Tablet PC
Nextbook Premium 8 Se Android Logo
371 people viewed this question
Top Nextbook Tablets & eReaders Experts
 Mike M
Mike M
Scott Fryer
john smith
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
