On the last spin cycle the wash shakes so violently that it almost comes off its stand. Then it shuts down because of the shake.
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
SOURCE: shakes violently during spin cycle from back to
Just remove the transport bolts that hold the drum during transport. Instructions should tell you to do this
SOURCE: Front load washer shakes violently during spin cycle
I had this problem as well.
I called dealer and Maytag.
They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad.
It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer.
Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
SOURCE: Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
SOURCE: ON SPIN CYCLE MY FRONT LOAD WASHER SHAKES VIOLENTLY
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
