Also microsoft windows 7 home premium
It sounds like you are trying to do an upgrade to Windows 7, as normally the operating system comes pre-installed on the Hard Drive (HDD). If the hard drive is not recognised, then it is a hardware fault, take it back it where you bought it!
If that is not possible, check that it is correctly fitted to the hard drive socket, otherwise it is back to a repairer.
SOURCE: Can't start up the laptop as Media test failure
I cant start up my laptop and it comes up black .. Then it says media Test failure Check cable. What do i do?
SOURCE: USB booting of external hard disk in HP laptop
You cannot boot Server 2003 from an external USB Hard Drive, it will have to be installed on an internal hard drive.
SOURCE: Acer Aspire 5100 Stuck in eRecovery boot loop.
You are going to need a boot up partition manager likeon the Ultimate Boot CD (ultimatebootcd.com). Boot to it, go into the partition program, then set the active partition back. Thanks and please take a moment to rate as fixya.
SOURCE: Trying to install Verisoft manager on Windows 7
after the incompatibility message, another window wil appear with two options: reinstall the software and software is installed and working successfully. click on reinstall software and it will install this time.
