Bosch maxx wfl 1300 instead of dumping the water out the discharge hose it floods the kitchen on some cycles. if i stop it and turn it to spin it then dumps through the discharge hose. what can cause this?
SOURCE: Bosch WFL 1300. The machine does not finish the
pump could be clogged or bad,or door switch is bad.any codes?
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
SOURCE: My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
SOURCE: can the bosch maxx wfl 2860 wash with only a cold water supply?
tromel står .setrefugen går ikke på en bosch WFL 2860
SOURCE: Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
dont think its a leaking hose because to stop it flooding i switch to spin and it dumps through the discharge hose properly
