Sometimes when you plug the charger in itll bring you to the blue U.s cellular. start up screen but will shut right back off.
SOURCE: Motorola Flash Mode
Can you hold down the center nav key and power up the unit? Then select Yes and perform a Master Reset on the unit. This should fix the file system possibly correcting the issue.
Is this a Q, Q9m, Q9c, or Q9h? Who is the carrier?
SOURCE: motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
SOURCE: Iphone will not turn on
Here are the steps to reset the iPhone. You probably performed the first reset, try the other resets.:
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: iphone wont turn off after reset.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
SOURCE: my motorola rokr wont turn on!
hold the camera button and then turn ON,then check if the phone goes to the flash mode ,the screen would turn completely RED
1. Power off the phone.
2. Hold the Camera button while turning on your phone
3. When
prompted to, hit the Volume-Down rocker button to go into Recovery Mode
4. In Recovery Mode, press ALT W to reset
5. Then Menu Back to reboot
This will erase your phone completely, restoring back to factory settings. All data will be lost when the phone is wiped.
First, try this:
If that doesn't work, or if your phone is frozen:
