Question about Panasonic TH Televison & Video
I have red snow through out my screen.How do i repair this problem because i have 5 kids waiting to watch tv.i am experienced in small electronics repairs and have the tools nescacary to change any c
Model th50pz80u first it starts out waves of red then when it warms up it turns the whole picture a blurry red.
6ya staff
SOURCE:
Anonymous
SOURCE: 42EDT41 colored snow/pixels
I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
Thanks a bunch in advance...
Posted on Oct 24, 2008
Jerimy_smith
Jerimy Smith
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
John Dube
  • 131 Answers
SOURCE: red line down right and left side of 42" LG plasma.
Hello; I am John at J D Electronics in Poland, Maine. I have an LG TV that was donated to me. It is a plasma model DU-42PX12X. It had 1 inch wide red and green vertical bar on the right and a blue and yellow on the left. These bars appeared intermittently. pressing on the control board would make the bars go away. I have read many blogs on this problem and they all say to replace the control board located under that huge A / V input board ( held in by 4 screws on the large aluminum frame). The original part is # 6871QCH038A The replacement ends with a C instead of an A Aprox 90 to 135 dollars. This board is used on many different LG and Zenith models and is a HIGH failure rate part. I like to know WHY parts/boards fail and I found out why this board fails. There is a large square IC in middle of the board aprx 1 1/8 inch square. This type of IC is called BGA or Ball Grid Array. The solder connections cannot be seen , since they are under the IC . This IC was not properly soldered at the factory and that is why hundreds of these sets failed. I used my hot air soldering station on it's highest setting to heat up this IC . The IC must be directly heated from the top and some heat on the bottom of the PC Board. Liquid flux should applied to the 4 side edges of the IC prior to heating. The bars are now gone! To get to this board, remove all perimeter screws and all middle screws of the back cover. The A V board will hinge back to expose the control board if you unplug the cables to the side inputs and the one to the button board. The set will still run face down on a table with something to prop up the bottom screen so you can watch the bars. If the set was run for a long time with the bars, there will be some darkening where the bars have " burned" the screen. This is perminent, but usually acceptable.
Posted on Dec 16, 2009
MICHAEL MULLINS
  • 927 Answers
SOURCE: Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
Posted on Jan 02, 2010
Testimonial: "Thanks for the advice, guy. I already replaced the 2 that were swollen, and now my TV is awesome again. Will replace all caps if it happens again."
Ivan
  • 308 Answers
SOURCE: samsung ln40a530 blinking red light, no video
Blinking lights are usually an error code. Do you have a manual that will decode the number of blinks? Its not always the power supply.
Posted on Apr 21, 2010
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Tip
How to build a backyard igloo!
Backyard igloos are easy and fun for kids. You don't need a large amount of snow, either. A few inches can be shoveled into a pile that's large enough for a kid to crawl into, but you need to be careful to make sure that you make it strong enough that it won't collapse easily.
Start out by piling the snow a couple feet high. Three feet is about as small as you can go, but that works well for most kids. It can be as big as you want, though.
After you pile it up, use a watering can to sprinkle the outside with water. It should be cold water, since hot water will melt the snow more than necessary. Make sure you cover the entire outside of the snow pile. The water is the key to making it strong.
Wait overnight for the water to freeze, and then use a shovel to scoop out the snow on the inside. Make a hole in one side with the shovel, and then carefully shave off the snow on the inside until you are close to the edge.
That's it! If the kids want, they can scrape out the snow on the inside with toy shovels, too. Overall time to do a small one this way is just an hour or so, not counting the overnight freeze.
on Jan 15, 2010 | Sport & Outdoor - Others
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Mar 09, 2013 | Panasonic Viera Tc-p42s30 42" Plasma Tv -...
When game boots, sound is present but tv screen is black
The problem you are experiencing is closely related to the dreaded RROD (Red Ring of Death). It has the same causes and solutions. I suggest getting an experienced person to repair your console for you. Take care that no one is doing the "Towel Trick" instead of an actual repair.
I run an electronics repair business and would be happy to fix your machine for you, email me at Jordan@jordanselectronics.com for more info
Dec 28, 2009 | Microsoft Xbox 360 Console
The screen has red snow with red lines going down the screen. What could be the problem? Thanks
Your YSUS is overloading, If you take the back of the TV off, its the larger board on the left, it is connected by orange ribbons to two vertical spanning boards that are thin and long, those are the buffers. Looking at your Y main, you'll see four small philips screwdriver adjustment recievers, they are about 1/4 of an inch square, these control the different voltages used by your board. They are tricky to align just right, BE CAREFULL and adjust these slowly with the power to the TV on and see if you can clear up the snow. PLEASE take it easy and watch what you're doing, these boards are running super high volatges and can put you in the hospital or worse. If you don't want to deal with it adjusting it, start by replacing that YSUS board. Usually when either the buffers or the YSUS is bad, it takes the others out with it. If the snow doesn't clear up, replace the buffers. If this still doesn't fix it, you can try replacing the XSUS.
Feb 02, 2009 | Philips 42PF9630A 42 in. Plasma Television
Dude I'm Lost!!!
Sounds like you have a short in the red drive circuit or CRT. If you are not experienced in TV repair you will probably have to contact a reputable repair shop. Good luck.
Aug 01, 2006 | RCA HD52W151 52" Rear Projection HDTV
Televison & Video Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
