Question about Drag Specialties POP-UP GAS FILLER AND FUEL LEVEL CAPS
How do you replace o-rings in a Harley pop up gas cap
Pop up gas cap not pushing down flush
    Master:
  • 706 Answers
Call NASA, they're familiar with the "o ring" problem. Go to your local library, it the reference section, there is a book that tells you how to complete this operation. OR just take it to the local Harley Dealer, It may cost you more, but it will be done right.
Posted on Sep 20, 2014
6ya staff
SOURCE:
Removing oil cap
If it i the flush type you just push and release to let it pop up then twist to unscrew about a turn.
May 27, 2013 | 2004 Harley Davidson XL 1200 C Sportster...
Take ignition off
1.) Remove Dash
2.) Remove Fairing Cap
3.) Rotate forks to Forward facing Position.
4.) Turn ignition switch to lock position.
5.) Insert key
6.) Hold button in and push key down, rotating counter clockwise.
7.) The switch will pop straight up.
8.) Careful of the large spring that will drop from bottom of switch as you remove it.
9.) Use 7/8" open end wrench to loosen the nut on top of the cylinder.
10.) Remove plastic ring.
Take care that assembly occurs opposite of removal.
Feb 27, 2011 | 2005 Harley Davidson FLHT - FLHTI Electra...
How do I open the fuel cap on a 2007 Harley Davidson 1200 sportster?
If it is a regular cap you just unscrew it. If it is a pop up one you push down and release and it will pop up, then you unscrew.
Feb 13, 2011 | Harley Davidson XL 1200 C Sportster Custom...
How to remove the ignition switch
1.) Remove Dash
3.) Rotate forks to Forward facing Possition.
4.) Turn iginition switch to lock position.
5.) Insert key
8.) Careful of the large spring that will drop from botton of switch as you remove it.
Jan 08, 2011 | 2005 Harley Davidson FLHT - FLHTI Electra...
How to change water filter in this refrigerator
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing system.
Hope this helpout.....
Aug 13, 2010 | Kenmore 57029 Side by Side Refrigerator
How do I replace my UltraEase water filter?
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Hope this helps...
Aug 12, 2010 | Whirlpool Refrigerators
Oil cap is leaking
Is there a rubber gasket or o-ring on the bottom of the oil cap? a lot of times that little gasket/ring will slip down when unscrewing and won't let you put the cap all the way back on.
Jun 01, 2010 | 2002 Harley Davidson XL 1200 S Sportster...
Flipping out
no threads on my 97'. have to continue to wiggle and pull then it pops out but not without quite a bit of effort.
Jun 29, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
How do you open the gas cap for a harley fat bob 2008
Obviously it's not the stock gas cap. If it's a flush mount. You push it in then turn it to the left while it's pushed down. it will pop up, then you can unscrew it normally.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Apr 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Drag Specialties POP-UP GAS FILLER AND FUEL LEVEL CAPS Logo
66 people viewed this question
Top Drag Specialties Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Drag Specialties Cycling Expert? Answer questions, earn points and help others
