Computers & Internet Logo
A
Anonymous Posted on Sep 15, 2014
I want cancel ask as search line
Altel landing Intel(R)Core(TM)i3-233
Guru Aid
Level 2:
Novelist:
Scholar:
  • Expert 104 Answers
  • Posted on Sep 15, 2014
Guru Aid
Expert
Level 2:
Novelist:
Scholar:
Answers
104
Questions
0
Helped
17222
Points
120
Ask.com is a browser hijacker. So, just changing your default search engine won\'t help. You need to get it out of your computer completely. To know how to do this, the following link can be useful:
http://www.fixya.com/support/t24728765-get_rid_ask_toolbar
Once done with the steps mentioned in the above link, you can then change your default search engine by following instructions mentioned on the following webpage:
Important: The following link is of a third-party website. It is recommended to update your security software thoroughly before clicking on the link:
http://www.wikihow.com/Change-Your-Browser%27s-Default-Search-Engine
Hope this will help you.
GuruAid.com
3 Related Answers
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Jul 15, 2012
SOURCE: laptop DISC drive not working find the problem and solution
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Anonymous
  • Posted on Nov 11, 2012
SOURCE: can i watch 3D movies on my acer aspire 5738 notebook?
can i able to view 3D movies in acer aspire one D270????
Anonymous
  • 571 Answers
  • Posted on Nov 21, 2012
SOURCE: internetexplorer not function properly and not sve download when i shut down my pc
Internet explorer is a basic internet browser. It usually has some problems just like what you are experiencing. I suggest that you install google chrome or mozilla in your computer.
Carlo
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
1helpful
Need to find witch motherboard fits gateway computor M-6843
http://support.gateway.com/s/Mobile/2008/Avalon/1015608R/1015608Rnv.shtml
Click on Components in the list.
Scroll down to -
Motherboard:
4006229R - Motherboard GM965 Chipset Intel Video W/10/100LAN No HDMI (FRU)
Click on the above.
Main View
Specifications
http://www.buy.com/prod/gateway-4006229r-gateway-m-6750-m-6755-m-6834-m-6823a-m-6846/209257968.html
http://www.codemicro.com/store/product/Gateway-4006229R-New.php
http://www.ebay.com/itm/Gateway-M-6750-Motherboard-31SA1MB0030-DA0SA1MB6E0-IS-read-carefully-/261119779234?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D3052480971542613513%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D270875445041%26
Just from some quick searches. Note that -
31SA1MB0030 is also another reference number.
May I ask what the problem is?
Power problem?
Do you have decent soldering/un-soldering skills?
For additional questions please post in a Comment.
Regards,
joecoolvette
Motherboard, name can be "foxconn"? If I can improve processor? If I have intel (r) core (tm) 2 duo 4300 @ 1.80 GHz one more powerful? Thank you
i belive that to be socket 775 if i am correct then yes you can get intel core 2 quad core 3 ghz per core hope thias helps
4helpful
I want softwares for intel(R) core(TM)2 Duo CPU E7300
Download it at www.intel.com then search for intel E7300 model & motherboard drivers
2helpful
Sound driver isnt working
hi there...try to download all driver mainboard at internet to make all system work...please write the brand,type/series of mainboard.(ex: ASUS P5KPL) and operating system that you use (XP or Vista)
go to search engine (ex:google) type it and search ... you will find the drver that you need for your mainboard..good luck..
5answers
Motherboard driver
i lose my Merury Mainboard Cd i nead the Drivers for PI945GCM Can any one help
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
