Dehumidifiers Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Delonghi de400p dehumidifier does not work
Everything runs, doesn't dehumidify
Anonymous
Level 2:
  • Expert 72 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Answers
72
Questions
0
Helped
14630
Points
196
If comp and fans running your out of freon or the compressor is not pumping more than likely out of freon and that means theres a leak in the sealed system high cost repair
1helpful
My dehumidifier does not seem to be working properly. I can't find the manual to tell me what the settings should be. Would appreciate your help. It is a DeLonghi DE400P. Thanks Shirley
What is the specific problem? Is no water being collected by the dehumidifier or do you have another issue?
Make sure that the dehumidifier is in a room in the operating temperature range (at or above 44 degrees F). Make sure that the room door and windows are closed and that the room is not larger than 2200 square feet. Make sure that the collection bucket not full and is properly seated in the dehumidifier. Check and clean the air filter on the dehumidifier. (Vacuum the filter or rinse under running water three times. Then wait until dry to replace it in the dehumidifier.) Look at the coils of the dehumidifier. If you have ice on the coils, defrost the unit (turn off, unplug and wait for it to melt). If the ice reforms quickly, you may have a leak in the coolant system. Then the unit needs repair.
Next make sure that you have good air flow around the dehumidifier and that the desired humidity set point is lower than the humidity of the room.
Retrevo has the manual available: http://www.retrevo.com/support/Delonghi-DE400P-Heating-Cooling-and-Air-manual/id/19269bh037/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
1helpful
Two years old Delonghi DE400 doesn't collect water, everything looks fine and running (no water but smell in basement).
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Bucket is empty but it is beeping
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Every thing works but no water gathers in the bucket
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
5helpful
Moisture not collected
low on freon is the compressor running?
Dehumidifier not removed moisture from air
heatman101
Delonghi de400p
same thing happend to me. I wasnt sure if it was the settings or me. I unplugged it for awhile, read thru the instructions turned it back on setting it according to the instructions and it began to work again. Not sure if it had to do with the unit being off for awhile or I entered the correct settings. Im just happy it began to run again
Lost owners guide to delonghi dehumidifier de400p showing code of e3
I am searching for a resolution to the E3 code (same init) and happened upon this request. The manual can be downloaded from DeLonghi.com but that advises you to call the service center.
Tom C
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
