Washing Machines Logo
S
Sandra Ward Posted on Sep 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I find out if the recalls/campaigns have been performed on my washer. It is leaking water, slinging oil and squeaks when in use.
This washer worked great for a while, but now has the aforementioned problems. It also sounds like a jet taking off when it is in spin cycle. The serial # CU0371066.
John Sweeney
Level 2:
Habit-Forming:
New Friend:
  • Expert 77 Answers
  • Posted on Sep 15, 2014
John Sweeney
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
77
Questions
5
Helped
14355
Points
224
When you load the washer, ,make sure the clothes arwe past the rubber seal just inside the door
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 23, 2008
SOURCE: leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Anonymous
  • 481 Answers
  • Posted on Jun 27, 2008
SOURCE: fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Anonymous
  • Posted on Apr 26, 2009
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
Anonymous
  • 2702 Answers
  • Posted on Oct 25, 2009
SOURCE: WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Anonymous
  • 91 Answers
  • Posted on Feb 03, 2010
SOURCE: water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
What are all the recalls on 98 cadillac deville northstar engine
3 Recalls for 1998 CADILLAC DEVILLE FILTER RECALLS BY AFFECTED COMPONENTS
All (3)AIR BAGS (1)STRUCTURE (1)VEHICLE SPEED CONTROL (1) August 11, 2000 NHTSA CAMPAIGN NUMBER: 00V217000
GM/SIDE IMPACT SENSOR MODULEHOWEVER, AN OCCUPANT CAN RECEIVE SOME INJURY FROM A DEPLOYMENT.
December 18, 1997 NHTSA CAMPAIGN NUMBER: 97V232000
GM/FMVSS 219IN THE EVENT OF A VEHICLE CRASH, THE HOOD COULD BE PUSHED BACK THROUGH THE WINDSHIELD GLASS POSSIBLY INJURING THE VEHICLE OCCUPANTS.
October 27, 1997 NHTSA CAMPAIGN NUMBER: 97V183000
GM/EVAPORATIVE EMISSIONS HARNESSTHE HARNESS COULD INTERFERE WITH THE CRUISE CONTROL AND THROTTLE LINKAGE PREVENTING RETURN TO A CLOSED THROTTLE.
1998 Cadillac DeVille Recalls ' RepairPal
https://repairpal.com > 1998-cadillac-deville > recalls
Oct 2, 2020 - Most Recent 1998 Cadillac DeVille recall ... VEHICLE DESCRIPTION: PASSENGER VEHICLES. SOME OF THE SIDE IMPACT SENSOR MODULES HAVE QUALITY PROBLEMS THAT CAN CAUSE ...
1998 Cadillac DeVille Reviews and Owner Comments
Oct 14, 2020
1998 Cadillac Eldorado Recalls ' RepairPal
Oct 13, 2020
1995 Cadillac DeVille Recalls ' RepairPal
Sept 30, 2020
More results from repairpal.com
1998 Cadillac DeVille Recalls & Safety Notices - Kelley Blue ...
https://www.kbb.com > cadillac > deville > 1998 > recall
View the 1998 Cadillac DeVille recall information and find service centers in your area to perform the recall repair.
1998 Cadillac DeVille Recalls - Autobytel
https://www.autobytel.com > deville > 1998 > car-recalls
VEHICLE DESCRIPTION: PASSENGER VEHICLES. SOME OF THE SIDE IMPACT SENSOR MODULES HAVE QUALITY PROBLEMS THAT CAN CAUSE AN INADVERTENT DEPLOYMENT OF THE DRIVER OR ...
1998 CADILLAC DEVILLE 4 DR ' NHTSA
https://www.nhtsa.gov > vehicle > 1998 > DEVILLE
Recalls & Safety Issues. This is a record of safety issues for vehicles of this year, make, model and trim. If you are a vehicle owner, search for recalls by ...
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
1helpful
2answers
Oil slinging from(off) belt/pully due to oil leak somewhere
Valve cover gaskets leaking, this vehicle is known for that. Easy way and lazy way=add stop leak= for the hard way but the right way=replace gaskets=
1helpful
Washer slinging grease from bottom of tub onto sidewalls of washer. Also beginning to leak water while it is agitating and spinning. Do I need Tub Bearing kit?
You need the outer tub seal as a minimum for the water leak. The grease is a different mater, it could come for several places by the most likely in the transmission, not the bearings.
2helpful
Grease inside washer
"When the seal starts to fail, this oil floats up into the wash water in the form of small black drops. The stains are almost impossible to remove from clothing. Also, as the oil is leaking up, hot soapy water is leaking down into the transmission, which will eventually cause it to fail. As I recall, the seal wasn't difficult to replace, but to get access to it,you basically have to disassemble the whole machine.
1helpful
Not spinning fast enough. Spins, but not as fast as it should, so clothes are still too wet to put in dryer.
I am going to assume this is a top load washer since you didn't specify. There are only a few causes. One would be having too many clothes and it is overloaded causing the clutch to struggle. Or the clutch could be worn out. If there is any water left in the bottom of the tub, then there may be a partial clog in the pump, or hoses somewhere taking too long to pump out the water. The motor may also be weak, but that is usually not the case. Sometimes the top oil seal in the transmission leaks and slings some oil onto the clutch pads making them slip and thus never get up to the proper spin speed.
Take half the clothes out and see if it spins fast enough. If it does, reduce your load size somewhat. If not, read on.
Unplug the machine and disconnect the hoses. Pull it out and tilt it back. Look up underneath to see if there is any signs of oil leaking. If so, the transmission oil seal needs replaced along with the clutch pads. If not, then if you have access to a Wet/dry shop vac, **** the water out of the drain hose. Lay the washer on it's back and remove both hoses from the pump to see if there is anything blocking the water passages. Something small, like a bra wire, can sling over the inner tub and get lodged in the pump inlet. That in itself is not bad but over time lint will collect around it. I have seen all kinds of things choke off the pump including small socks, rug stringies, coins, jewelry chains, etc.
1helpful
1998 nissian altima engine floods at random
gosh, nissan spent 6 million dollars replacing faulty/leaking fuel injectors around that time ...maybe its worth a trip down to the dealer and do a campaign/recall search on your car...might be a car that was covered under that campaign and you might get injectors covered
Top Washing Machines Experts
john h
