Question about Tablets & eReaders
This is what I received as recommendation because my Samsung tablet wonturn on and I was given the following tip: "Try to hard reset or soft reset, for this procedure search on google.com how to reset
This is what I received as recommendation because my Samsung tablet won't turn on and I was given the following tip: "Try to hard reset or soft reset, for this procedure search on google.com how to reset tablet, that will be helpful".
  • Arlenice Carbajal Sep 15, 2014
    I haven't hard reset it because I don't know how to... It was suggested that I search google.com to reset tablet. That's how I got to this site.
  • Tablets & eR... Master
  • 4,639 Answers
Restore Deleted Files on Samsung
The Android data recovery
could be best helper to recover deleted files on Samsung thoroughly. It is a professional data recovery tool good at restoring deleted data from Android device. A various types of Android data are supported, for instance, contacts, text messages, photos, videos, call logs, WhatsApp messages, apps data and more. It could be used to perform Android data recovery for any data loss causes.
More importantly, this program have other function, which are Android data backup & restore, recover data from broken Android. It is compatible with almost all models of Samsung and other Android models, including Galaxy S9/S8/S7/S6/S5, Note 9/8/5/4.
LEARN MORE
Posted on Oct 15, 2019
    New Friend:
  • 16 Answers
Please specify the model number of the Samsung tablet..
Posted on Sep 16, 2014
  • 4,290 Answers
Http://www.samsung.com/us/support/faq/FAQ00055283/66871/SM-T3100ZWYXAR
If you give us the model number then we may be more accurate with our answers as this was you a Samsung Galaxy Tab 3 but I think the procedure would be similar across all samsung tablets.
6ya staff
SOURCE:
Galaxy tab 3 flashes on and off with a android with a trianhle and exclamation point also wont charge
Your firmware is corrupt. You could try a hard reset to factory reset the tablet. But I recommend a clean flash. If possible watch the video that explain on how to hard reset Samsung Tablet 3.
Jul 10, 2016 | Tablets & eReaders
Rca tablet will not power on
First of all, it is recommended to try and charge your tablet for at least 1 hour. Now try to start the tablet and if that does not start, then follow the step given below:
- Use a small, thin object, such as a paperclip, to press the recessed reset button located on the bottom of the tablet.
- If done correctly, the tablet will power off and restart once and you will able to see the screen.
- If tablet still do not charge or start, it is recommended to contact tablet manufacturer for further assistance or repair it.
GuruAid.com
Jul 05, 2016 | Tablets & eReaders
My Samsung galaxy Tab 3. 10.1 will not charge I believe it is the port. What can I buy or repair to fix it and where and we he cost estimate
If tablet still do not charge or start, it is recommended to contact 'Samsung Service Center' for further assistance or repair:
http://www.samsung.com/us/support/contact
GuruAid.com
Jul 01, 2016 | Samsung Galaxy Tab 3 16GB 10.1-Inch White...
My tablet is hang how can restart all button are not responding
My first guess is that It is "frozen." If you turn it off and back on, it probably asks for an "unfreeze" code related to unlocking the phone. If that is the issue, you can try to work with Samsung's support via their live chat. http://www.samsung.com/ae/support/model/SM-T331NZWAXSG
This may be helpful related to the above:
http://www.unlocking.eu/how-to-enter/samsung-t331-galaxy-tab-4-80-3g/
I included the above link simply for illustrative purposes. The avove is if you entered the wrong code 3 times that locked the phone.
But alternatively, if the device is truly "hung", you can try first a soft reset and if that does not work, a hard reset (which will return the system to the factory defaults reverting it to how it was when it came out of the box. With a hard reset, you lose whatever you did on it after you took it out of the box.
If you do a soft reset and you get some access to the keypad functioning, you might want to uninstall whatever you probably just installed immediately before it froze up. A soft reset retains your data. I would avoid trying the last program you installed again to see if it ran! You might subsequently download the SD Maid app and select corpse (no kidding) to get rid of residue after the uninstall of what is the problematic program.
Hard reset Utube: https://www.youtube.com/watch?v=nZBZYa4nZ18
Soft reset: http://smallbusiness.chron.com/soft-reset-samsung-galaxy-s4-81670.html
Jun 03, 2015 | Samsung Galaxy Tab 4 8.0 3G T331 16GB GSM...
How do I clean my samsung galaxy tablet
You can try to delete unnecessary files go to Settings, select Apps then click on Program.Select the apps that you want then click Uninstall. To stop unnecessary programs running in your phones background go to Setting, choose Apps. Select Running then click on the program you want to stop then select Stop. Restart your phone. If you experience the same thing then you might need to reformat your mobile. Before you do the soft reset on your mobile be sure that you have a back up copy of your personal files because it will be deleted after the reset. Be sure also to fully charge your device. To soft reset your phone go to Settings. Select Privacy then choose Factory Data Reset then choose Reset Phone then click Reset Everything.
Dec 27, 2014 | Samsung Galaxy Tab 101 Tablet...
I have a Craig 7 inch touch screen tablet it comes on but doesn't load
Dear Craig User,
I understand your delima with this tab, however unfortunately this product doesn't carry a very good market reputation.
For the kind of issue you are facing, I would recommend a reset (Hard reset) for which you may follow the following procedure.
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Post your update, let us know if it helped.
Regards,
Sid
Nov 12, 2014 | Tablets & eReaders
How do i reset the password on my galaxy tablet
In order to hard reset your Samsung tablet, the steps given below must be followed:
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory resetoption (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing thePower button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Oct 08, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
Received in the mail today 3 of the 7" Genesis Prime tablets for my kids. One of the tablets is saying "Unfortunately the UI stopped & Unfortunately the Wizard has stopped" I didn't have any problems...
UI means "user interface." It likely means "GUI"--"graphical user interface"--pretty pictures on a screen upon which one points and clicks. Thus, you can't use the touchscreen. Try a "soft" reset. If that's ineffective, try a hard reset--often called something like "Restore Factory Settings." If you find the manual, physically--or online via a mfr. site PDF, follow it's procedure for those. Otherwise, try pressing the power on button for 20 seconds or so--see if the screen then offers hard reset. Press "Yes" or otherwise assent.
Dec 19, 2013 | Tablets & eReaders
Zeepad has frozen!! how can i reSTART it without waiting for the power to die out ???
In order to hard reset your tablet, the steps given below must be followed:
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
Oct 02, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
Tablets & eReaders Logo
339 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
