I am in a Motor Home with old analog Tv's. Went to Walmart and purchased a 32" led Tv to hook up to there cable. Picture is perfect but I have No Sound. Took the Tv back to Walmart thinking that there was something wrong with the TV. 2nd Tv doe's the same thing. I am confused !
SOURCE: Emerson LD195EMX - just bought from Walmart,
Hey, most stations are not broadcasting analog anymore. That is why you are only getting 10 channels.
SOURCE: I purchased a 32" Emerson
Hi ma3580,
If you can take a it a part, check the connection of the controller board through your main board and the power supply board. Pull-out all connectors then re-inset, this is to confirmed that there is no bad connection issue from this board. If the symptom still persist this is a time to replaced the controller board. Click this link http://shop.ebay.com/i.html?_nkw=LC320EM8&_sacat=0&_odkw=aaa+battery+pack&_osacat=0&_trksid=p3286.c0.m270.l1313.
If you can't do the job yourself, I would advice you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
SOURCE: I have a Emerson LED 32 LF320EM4A has sound no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
