Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
A
Anonymous Posted on Sep 15, 2014
I have sony bravia lcd 46inch tv.getting straight lines on the screen. Picture is not clear. What might be the problem?
Straight lines are spreading all over the tv. Picture is not clear due to straight lines.
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Sep 16, 2014
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994472
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5 Related Answers
Anonymous
  • Posted on Jan 31, 2009
SOURCE: Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Anonymous
  • 197 Answers
  • Posted on Jul 02, 2009
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Anonymous
  • Posted on Oct 09, 2009
SOURCE: I have a new Sony Bravia 46inch LCD tv with direct
i have a 46 inch sony bravia that i bought in 2007. recently i have noticed that the screen is showing horizontal lines (purple?) about that come and go. any advice would be greatly appreciated
Anonymous
  • Posted on Jan 29, 2010
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
CoppellTVRepair.com
  • 778 Answers
  • Posted on Mar 15, 2010
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
My sony bravia LCD 40 inch is appearing 2 straight lines on the screen and they are perpendicular to each other. These are now permanent lines and they are disturbing when watching tv, what could be t
3helpful
We are having issues with the screen. The display of our Sony Bravia KDL-40V4150 shows straight vertical lines all the way across the screen. How do we fix this issue?
Sounds like a defective T-Con board, but it is better to test it before replacement. Also there is a possibility to repair it at a lower price. You can find a company that is testing this kind of T-Con boards and repair them here: http://www.coppelltvrepair.com/p/540/repair-service-for-auo-t400hw01-v5-40to2-c06-40t02-c06-lcd-timing-controller-t-con-causing-bad-tv-picture
3helpful
2answers
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Sony Bravia 52" 1080p LCD Full Pixel Mode Screen Problem
HI NORMALY WE ADJUST THE PICTURE THROUGH SIZE PLEASE GO TO PICTURE SIZE ADJUSTMENT AND ADJUST THE SIZE
THANKS
MUHAMMAD NASIR
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
No picture no sound, power light is on and tv has clicking sound every 6 seconds
Unplug TV straight away and contact Sony technical support on 0845 6000 124. If under warranty, will get repaired for free. Sounds like the Backlight lamp trying to switch on but something in the powerboard is preventing it.
3helpful
2answers
I have a new Sony Bravia 46inch LCD tv with direct TV remote RC64R, what code can I use to get my remote to work? I've tried all the codes in the book.
Sony 46inch tv will not come off standby from the remote
its the main board poroblem.its due to the components on the main board getting over heated due to got loose internally or short in between. have to be checked with a meter and replaced.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
