Lense will not extend properly
SOURCE: Fuji s6500 different lenses
hi kelize, you were looking for a "telephoto" lens for your "fujifinepix s6500fd" and so was i , i have found and ordered a "raynox dcr 2025" with adapter for mine, 2x2 magnification, dont know if i can tell you where on the post , but i will and hope they put it up for you, (advertising! some forums dont like it) it is www.digitalfunstuff.com.au hope this helps, riki.
SOURCE: fuji finepix s7000
I just then took the previous posts idea and pulled the lense off and cleaned light sand out of it , extended lense as told, put back together and turned on.so far focus seems good
SOURCE: fuji finepix f50 camera was
Unfortunately dropping this model, and the f40, 45, 47 fd models, is suicidal for the camera. The lens has an inner slide ring which other models do not have and this ring has three lugs to keep the lens from spinning when powered up and used. Unfortunately these lugs are also clips which hold the focus lens inplace. These are tiny. hard to repair
SOURCE: Fuji Finepix S3500 camera not recognising fully charged batteries
get a new camera sorry thats an old thing when it runs out its out sorry
SOURCE: how do I fix the Zoom Error for Fuji Finepix
Hi Jasmine,
With fresh batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances
are, there could be a sand or granule of dust that got stuck on the
sides of the lens, preventing it to retract properly.
Hope this helps.
