Our Kenmore is making a cracking sound and will not agitate or spin - looking to replace. I'm looking for the load capacity of the washer.
SOURCE: model 110.22952100 Kenmore Elite Heavy Duty Washer
how to remove agitate from a kenmore elite
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
SOURCE: kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
SOURCE: Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
SOURCE: Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Testimonial: "Thank You! The diagnosis confirmation and repair video helped. There were some differences between my Washer and the repair video, but figured it out"
