BaByliss 2285BU Hair Curling Wand Logo
E
Emily Coughenour Posted on Sep 16, 2014
My Babyliss hair curler would light up when I press the power button but then it would shut off again. Am I doing something wrong?
I just received my Babyliss curling wand 2285BU and wanted to curl my hair. I had to put on the adapter and it would light up when I press the power button but would disappear. After a few attempts it started to work. I was midway done with my hair until it completely shut off and I would then press the power button and it would light up and then it would shut back off again. Is there a way to fix it? Is it the converter (since plugging it in it started to smell like burning metal)
1 Related Answer
dazburt03
  • 10 Answers
  • Posted on Feb 23, 2015
SOURCE: BaByliss 2082CU Pro 235 Hair Styler these won't seem to heat up enough on highest setting, brand new
Enter the serial number on the babyliss website to ensure you have a genuine hair styler, if genuine ask for your equipment to be swapped or repaired at there cost
I just bought the Conair Curl Secret. I was trying it out. It worked great until my hair got a little tangled in it. it shut off and won't come back on.
Question edited for clarity and toss in some CAPS.
It is under warranty so reach out to Conair Support or Babyliss Support. Full make model (what it is)' in all questions please.
CURL SECRETâ„¢ 2667U SAFETY CAUTIONS
BaByliss UK https://www.babyliss.co.uk > en_GB > informati...
To allow the curl to set, do not comb or brush the hair until it cools. • Repeat around the head until you have the amount of curls desired. • After use, switch ...
Perfect curls! New Curl Secret automatic hair curler
Conair https://www.conair.com > curlsecret
The reimagined Curl Secret is the drama-free way to achieve perfect curls. Curl your hair with the ultimate automatic hair curler.
1helpful
2answers
How long should it take for light to turn white on babyliss pro curler set?
For most curler sets it's usually within 3 minutes... I know it seems like a long time when your waiting for it. Hoping this helps .
How to change battery for a babyliss pro fx760
Hi! To change the battery for a Babyliss Pro FX760 hair trimmer, you will need to follow these steps:
  1. Make sure the trimmer is turned off and unplugged from the power source.
  2. Locate the battery compartment. This is typically located on the bottom or back of the trimmer.
  3. Remove the battery compartment cover by pressing the release button or sliding the cover open.
  4. Remove the old battery by gently prying it out of the compartment using a flat-headed screwdriver or a similar tool.
  5. Insert the new battery into the compartment, making sure it is oriented correctly and seated securely.
  6. Replace the battery compartment cover by sliding it back into place or pressing it down until it snaps into place.
  7. Plug in the trimmer and turn it on to test the new battery.
It is important to note that the specific process for changing the battery in a Babyliss Pro FX760 trimmer may vary depending on the specific model and design of the trimmer.
Note: The battery in a Babyliss Pro FX760 trimmer may vary depending on the specific model and design of the trimmer.
I have a babyliss hair dryer mod. 6619E type S54d The dryer turns on but after a few second it turns off What is the reason.
is it throwing a reset switch on its plug head? if so press the reset button on the plug head if it trips again there's an issue inside the hair dryer thats making it shut off power to it from the plug head
Where can I get the babyliss pro curler
http://www.amazon.co.uk/s/?ie=UTF8&keywords=perfect+curl+babyliss+pro&tag=googhydr-21&index=aps&hvadid=24555785814&hvpos=1t1&hvexid=&hvnetw=g&hvrand=18206864247046079762&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_2ky6pkn4hy_b
What's a good hair curler for fine hair?
I have fine hair and could never get it to hold a curl, let alone a wave. But I am finally able now that I bought the Hot Tools Ceramic professional curling iron. I am really happy with it!
Top BaByliss Health & Beauty Experts
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
