This tv is now 1 year 3 8 months old.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
