No video on boot up I just got this 330 and can't get my monitor to work i tried 2 of them
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
SOURCE: Error: Cannot Display This Video Mode
I fixed the problem as follows:
1/ Uninstall the existing display driver through Device Manager
2/ Reboot the PC - Should display fine with default Windows driver
3/ Install new display driver from windows update or DELL Support
All should now work fine.
DCF
SOURCE: Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
SOURCE: i get orange light on
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber, bad power supply
Solid Amber either a bad component connected to motherboard of the motherboard itself has failed
SOURCE: my Dell Optiplex 330 does not turn on,there is a
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might occur.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
You an use the following link to know how to open the computer tower
User manual
Thanks for using Fixya
Proton
