Fitbit Ultra Tracker Logo
E
Erin sherbs Posted on Sep 17, 2014
How do i connect my fitbit device to my verizon tablet.
I need to find out how to connect my fitbit device to my verizon tablet. dont know how to connect my device to my tablet. i do not now who to plug it in.
Leo Libby
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Feb 15, 2015
Leo Libby
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
21346
Points
19
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
I just received a Fitbit Inspire - Do I have to have a Cell phone to use it? Is there a manual to use it?
No, you do not necessarily need a cell phone to use a Fitbit Inspire. While syncing the Fitbit with a smartphone can enhance its functionality by allowing you to receive notifications and track your data more comprehensively, you can still use the Fitbit Inspire without a smartphone.
To set up and use your Fitbit Inspire, you can follow these general steps:
  1. Charge your Fitbit: Plug your charging cable into a USB port or wall adapter and connect it to the charging port on the back of your Fitbit Inspire. Charge it fully before you start using it.
  2. Create a Fitbit account: If you don't have one, you will need to create a Fitbit account. You can do this on the Fitbit website or through the Fitbit app on a smartphone or tablet.
  3. Set up your Fitbit: Follow the on-screen instructions on your Fitbit device or the Fitbit app to set up your device. This typically involves connecting your Fitbit to your Fitbit account.
  4. Wear your Fitbit: Put on your Fitbit Inspire and start tracking your activity, sleep, and other metrics.
  5. Sync with your phone or computer (optional): If you have a smartphone or a computer with Bluetooth capabilities, you can sync your Fitbit data with the Fitbit app or Fitbit website to see your stats, set goals, and track your progress more comprehensively.
Jun 20, 2019 • Cell Phones
My fit bit no longer syncs on my phone
You will have to Go to Settings> Bluetooth and turn Bluetooth off and back on. Open the Fitbit app. If your Fitbit device didn’t sync, restart it. If your Fitbit device won’t sync after your reinstall the app, log in to your Fitbit account on a different phone, tablet or computer and try to sync
Jan 14, 2019 • Cell Phones
Manual for Alta Fitbit How do I set the time and date for my fitbit
You set the date and time from the Fitbit App or Fitbit Connect when you setup or sync the fitness band with the computer/tablet. Open the Fitbit Dashboard and then tap (or click) the Account icon. Enter the Advanced Settings menu and check the Time Zone section. If needed, turn off the Automatic option and manually set the current time zone. The Alta will display the date and time based on the time on your computer/tablet when you synced the devices. See https://help.fitbit.com/articles/en_US/Help_article/1176/?q=set+date+amd+time&l=en_US&fs=Search&pn=2 . This is the "How do I change the time on my Fitbit device" FAQ.
Alta has the manual for the Fitbit on the product support page: https://help.fitbit.com/?p=alta . The direct link to the manual is https://staticcs.fitbit.com/content/assets/help/manuals/manual_alta_en_US.pdf . Additional device help is available at the help page: https://help.fitbit.com/ .
I hope this helps.
1helpful
I have a new fitbit and can not get it set up
How do set up my tracker
The link above gives the steps: "Before you begin using your Fitbit device, you must connect it to your Fitbit account with a phone, tablet, or computer. Connecting your device allows it to transfer (or sync) data back and forth with Fitbit.
Sync my fit bit to my Apple ipad
If your device still won't sync, try these steps:
  1. Force quit the Fitbit app. ...
  2. Go to Settings > Bluetooth and turn Bluetooth off and back on.
  3. Open the Fitbit app.
  4. If your Fitbit device didn't sync, restart your iPhone or iPad. ...
  5. Open the Fitbit app.
  6. If your Fitbit device didn't sync, restart it.
Help article: Why won't my Fitbit device sync?
help.fitbit.com/articles/en_US/Help_article/1866
2answers
A verizon tablet. I don't find or see a model #
Search Results
    Verizon Ellipsis 8 4G LTE Tablet, Black 8-Inch 16GB
    www.amazon.com > ... > Mobile Broadband > Tablets
    Amazon.com, Inc.
    Rating: 2.3 - ‎46 reviews
    Ellipsis 8 Tablet 16GB, Wi-Fi + Verizon 4G LTE, 8in - BlackNetwork Type: CDMA .... After only one charge, I don't find either inferior to other android devices I've used. .... the worst mini tablet possible they would be well advised to model it after this ... Check out these pages to see more: verizon tablet, case eclipse 7, verizon ...
    Verizon Ellipsis 7 4G LTE Tablet, Black 7-Inch 8GB
    Amazon.com, Inc.
    Rating: 2.3 - ‎178 reviews
    See all Open-Box & Preowned offers from Amazon Warehouse Deals. ... Ellipsis 7Tablet 8GB, Wi-Fi + Verizon 4G LTE, 7in - BlackNetwork Type: CDMA ... Learn More; ASIN: B00GJ3MF9Q; Item model number: Ellipsis 7; Average ... it...guess they don'twant people to know the truth about their first foray into the tablet market.
    Verizon Ellipsis 8 Support ' Verizon Wireless
Photos on verizon tablet were not stored on sd card, how do I get them on sd card
According to Verizon support:
"From the Device to a Removable SD Card This feature is not available on the Verizon Ellipsis 7 Tablet"
However, you can transfer photos from the tablet to a computer; and then you can transfer them to a removable SD card if you have an external USB SD card port reader or one that's PC integrated.
According to Verizon customer support:
From the Device to a Computer
  1. Connect the device to a computer using the supplied USB cable.
    1. If necessary, select and hold the status bar (at the top) then drag to the bottom.
    2. Select Connected as a camera / an installer.
    3. Select Media device (MTP).
  2. Launch Windows Explorer.
    linote.gif Using the computer keyboard, press Windows+E ( windows_key_logo.jpg+E) keys.
    linote.gif Alternatively, right-click Start then click Open Windows Explore.
  3. Using Windows Explorer, navigate: QMV7A.
    linote.gif If you have a microSD card, you may transfer files to that location by navigating: QMV7A > SD Card.
  4. Utilize the computer to copy video/picture files from the following folders to the preferred folder(s) on the computer:
    • DCIM/Camera
  5. Disconnect the USB cable from the computer.
I cannot connect my mifi verizon hotspot device to my transformer tablet tf300
Delete any other 'mifi verizon' connections from the 'wifi and networks' then restart (switch off for 10 secs by removing power cable) on both mifi and tablet and try agiain.
Top Fitbit Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Fitbit Home Security Expert? Answer questions, earn points and help others
