SOURCE: LG front load washer WM2277HW. ''LE'' Error code
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
SOURCE: LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
SOURCE: My 7 year old LG
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
