Question about Kenmore 600 3.5 cu. ft. Top Load 110-2962 Washer
Will not fill with water
Water will not fill up in my machine . It ill spin but there is no water in it
2 Suggested Answers
6ya staff
SOURCE:
heeman mohun
  • 1341 Answers
SOURCE: Machine spins without filling up with water first.
Check your water valve intake system.it is a small device located at the point of entry of your water hose.
Posted on Nov 05, 2009
Why does washer sometimes fills with water continuously / yet never fills up?
Many laundry machine hoses require a physical air gap, or air break, between end of hose & standpipe drain. This prevents both siphoning & sewer water backup entering washing machine... ( UPC ill. Manual for picture) ... Buzz*
Jun 24, 2018 | Roper Washing Machines
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Why won't my maching spin? It will fill and agitate, but not spin.
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced
best of luck
sonic boom electronics australia
please remember to rank this advice if it helps
Dec 02, 2010 | Kenmore Washing Machines
Washer will not start/continue with cycle
check if the water pump is not blocked in any way preventing the water from emptying properly as the machine wont continue until the water sensor tell the machine that its ready for the next cycle the pump may not be doing its job preventing the next cycle to take place eric
Jan 15, 2018 | Kenmore 24872 Top Load Washer
As washer was on final spin cycle it sounded like a belt came....
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Kenmore Washing Machines
My Amana LWA60AW washing machine won't agitate, the cloths just spin through the cycles.
so when hte uint fills, it oges directly to a spin mode insteadof agitating??, Ill assume that in agitate mode, it apperars to be spinning??? if this is the case aounds as if you need to replacehe brake pads, the tub is not being held!!!!
Mar 28, 2009 | Amana Washing Machines
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series won't agitate or spin
Motor coupling is broken, this is a very inexpensive part and the new one is improved.......purchase one from any appliance part store and ill help with installation. There are quite a few tricks to axcessing the motor but if you handy its a cinch .
Jan 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
