Tried control alt delete but locked on switch user, blinking blue and yellow shield on bottom of screen but can't activate it
Try holding the power switch for 15 seconds, or until it turns off your computer and then restart it again and see if that helps. Also check if an external USB mouse (from a desktop computer or from a friend) works. Plug it into your laptop and wait for it to install(up to several minutes) and see if it moves the cursor.
SOURCE: Toshiba Satellite A135-S2376, black screen problem
Just bought a Satellite & had same problem. Toshiba Support confirmed the 'Processor Power Management' fix. Within both the Min AND Max Processor State options you should set BOTH the Battery and Power Adapter options to 100%
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
SOURCE: cant see desktop screen
Try this if your problem sounds the same or similar:
I purchased the HP-Compaq C765TU Presario, serial # CND81233B5, from Octagon Computers. My notebook came with only "Freedos" because I was going to Dual-boot Windows XP Professional & Linux, but I found out that my notebook is only “Vista Compatible,” because I could not find the drivers for the sound card & Atheros wireless adapter & the Linux I used, Ubuntu does not have all the drivers needed, so I uninstalled, & I added the only Windows Vista OS that I could get here at Octagon Computers in Tacloban City, Leyte, Philippines, “Windows Vista Starter!” (I’m an American married to a beautiful Filipino woman 1 year younger than me, & we are living in the Philippines. I’m, also, Retired USAF.) I went to the HP-Compaq site & downloaded all the new drivers and essential update for my notebook to make sure my notebook was as it should be by HP-Compaq standards. All is well, but only for a little while!
The first problem that I encountered was that after I would Logon, the Welcome screen would do its processing then go to a blank desktop with the cursor - no icons, no taskbar, nothing, so I used “control, alt, delete” to bring up the tasks page & started Task Manager. I found that the “Explorer.exe” was not listed, so I ran a “New Task” from the file menu, & my whole desktop came up. The notebook runs fine after this is done, but I had to do it all the time.
So, I found & bought a copy of Windows Vista Ultimate on the Internet & was forced to do a clean install because it was a full version (not an upgrade), which formatted my Hard-drive, but I had backed up all my files ahead of time, so as to not lose all my important data. I went back to HP-Compaq site & downloaded all the new drivers and essential update to make sure my notebook was as it should be by HP-Compaq standards. After doing this New Install, my notebook worked perfectly! However, the same problem has come back as I had with Windows Vista starter.
I have always used Anti-virus, and I run “System Mechanic Professional 8” because it has all the tools needed to seek & destroy viruses, spybots, etc…, & recover/repair data.
I have never had this problem with Windows XP Professional, but this laptop is designed for Vista, and I didn't know that before I bought it. I'm still looking for a permanent FIX. There must be a way to fix this problem permanently!
I have an asus pc 1000hd that does this every now and then. I hold the power button down and the whole machine shuts off after a few seconds. Either that or you can take out the battery, wait a few seconds and then reinsert it
